7 hours ago, M1ck3y said:
Right, I’m wondering how much my top speed will drop after changing gears…
In my GMT900 trucks, both steel and aluminum driveshafts are limited to 5,000 rpms.  Same for the steel front driveshaft.
If we assume the same applies to your generation truck, your driveshaft would be turning 4,977 rpms at 142 mph in 7th and 8th gear with the tires currently on your truck worn down to 2/32nds of an inch.  At 143 mph, the driveshaft would be turning 5,013 rpms.
With 3.73 gears your top speed is now 123 mph with the shaft turning at 4,973 rpms.
With 4.10 gears your top speed is now 112 mph with the shaft turning at 4,982 rpms.
Now having said that, we've seen on this and other forums many photos of aluminum driveshafts twisted into pieces when fellas took their K2 generation trucks to the magic number of 112 mph.  That's the speed several reported going when their shafts self-destructed.
We also have photographic evidence of a stock tired 2012 Yukon XL Denali going 143 mph or so and his driveshaft would have been turning about 5,400 rpms.
8 hours ago, GETGONE said:
Unless you're tuned it won't matter anyways since it's electronically limited to 112mph.
I drive a 17, and it is tuned. I posted here because I’m trying to get as many knowledgeable responses as possible.
The driveshafts on k2’s go out 120 - 130. And I’ve read that the max tow trucks came with a lower top speed around 90 or something (down from 100). So I assumed it must have dropped because of the 3.42 ratio. Which is a substantial drop for such a small change.
I was hoping someone would have specific information regarding my driveshaft. The shop I’m working with wasn’t much help.
Edited by M1ck3y
I have a 21 with the 6.2 and have hit 112 NUMEROUS times so the driveshaft thing is BS on the T1 trucks.
Until I joined here I always thought the limit was because of the tires. All my trucks were tuned at the minimum. All had limits removed or moved up. Never had a drive shaft problem or a hint of vibration. Speed limits are high here people routinely cruise at 80 MPH. It hard to believe the driveshaft is out of balance enough to be close to explosion. And not be felt at cruising speeds of 70-80 MPH. I rarely went that fast in my trucks running aggressive high ply tires. The drive shaft never entered my mind.
The limit IS due to the tires. That's why trucks with the 18's have a 98mph top speed and the trucks with 20's have 112mph because of the tire's speed rating. S vs T.
Like most rotating stuff that's balanced, it's balanced on a machine, to work up to a certain rpm.  Going just over that rpm doesn't mean it will vibrate, or fail, just that it is unknown as to what will happen.  As well, going faster also requires a lot more power that the driveshaft also has to handle, so it's both spinning faster than it was balanced for, as well as having a lot of torque applied to it.
Doesn't balanced mean balanced?
I have not heard of anything being balanced by RPM etc, do you have an example of this?
I am happy to be educated on it if you can think of something.
TIA
A balancing machine spins an object up to a certain rpm, and then uses sensors to figure out if/how much it is out of balance at that speed, and what weights need to be placed where to get it balanced within some tolerance.
So, an wheel or a crankshaft for an F1 car gets spun up to a much higher RPM vs the ones for regular cars, to balance them, because they get spun up IRL that much faster.  The parts are balanced for any rpm up to those rpms, but if you get them going faster than that rpm, then smaller and smaller weight differences will cause vibrations.
The tire balancing machine at shops is a common example, it gets the tires up to a certain rpm to balance them.  Going past that rpm in real life, you may experience vibrations from the tire.  If the tire guy is doing his job right, he'll balance a tire for a Chevette at a much lower rpm compared to a Corvette.
Exactly, just an example, driveshaft balanced up to 6000rpm with 1oz weight over 6000rpm that same 1oz weight turns into around 150lbs of force anything higher in rpm now the shaft is out of balance and will start the vibration as rpm increases it gets worse. Same goes for tire balancing as davester said.
Edited by Silverado4x4
GM might decide to limit speed below the trating of the tires (for whatever reason).
Hard to believe they would even think about accepting the liability of having the vehicle speed limiter above the rating of the tires they installed.
Will tires fail immediately if rated speed is exceeded?  --- of course not .
Edited by redwngr
  • Confused 1
Well, unfortunately they don't make Z rated all terrain tires..
In central Texas we have SH130, where the posted speed limit is 85 mph. And if you're going that slow, you need to stay to the right lane!Screenshot_20251106_193457_Chrome.thumb.jpg.75061b0ac81f032e51eca8647285d632.jpg
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   0 Members, 0 Anonymous, 573 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
