Based on my RPO codes I have a G80 rear diff. No trace of su7 or su8 which seems to be the common rear diff.
 I’m trying to find the correct gasket and also with the g80 it appears you’re not to use limited slip additives. I crossed 100k miles so figure the service is due.
Is this g80 in a su7 or su8 housing?
5.3L L84 SLT.
diff cover/size/shape does not change whether there is a g80 inside or not.  If you bought the truck used, anything could be inside.  It probably still has the g80, but it might have been swapped to an open diff (my '04 3500 was), or it may have been swapped to some other locker.
And you don't want to use limited slip additives w a g80.
5.3L L84 SLT.
You need the full build sheet or call the dealer with your VIN and see what axle you have.  The cover gaskets are different between SU7 and SU8.
SU7 axle uses 85720902 which is a rubber coated steel gasket.
ACDelco 22943110 Genuine GM Parts Differential Cover Gasket
SU8 uses 84412728 which is a fiber type with a lip seal on the inside of it.
84412728 - Rear Axle Housing Cover Gasket 2019-2025 GM | GM Wholesale Direct
2 hours ago, silveradosid said:
it is a 12 bolt diff so the gasket should be 85720902
Two different gaskets.  SU7 and SU8 use two different gaskets.  Both are 12 bolt.  See my above post.
Edited by newdude
The Dealer should help like stated above.  You could always buy both gaskets and when you remove the cover see which one you need.  On my 2019 silverado I just reused my gasket. It was the rubber coated one just like on our 2016 suburban, which I reused as well, no leaks.
Pic/screencap borrowed from AFE. You can look at the identifying marks on the differential to tell which one it most likely is.
You can see how the gusseting and characteristics of the covers are slightly different.
There are similar pics out there for the front diff if you're looking for that too; it's even easier to identify as the cover is a slightly different shape.
Edited by Atlas
    • You need a better code reader/scanner.  You are missing codes.  Did the dealer give you a copy of the SAVI scan from that visit?     If the fluid hasn't been changed, change it.  Shudder will likely go away.
    • TLDR to my other post...   Hard. Pass.  Too many what ifs.     Are you set on a 3.0 Duramax?  Have you considered anything not GM just in case?  If you don't have to have a pickup, lots of other options for $27,000 out there.
    • I see some red flags.   - No mention in the Carfax if the oil pump belt was changed.  LM2s had a 150,000mi service interval, and its got 164,245mi on it.  So right out the gate it needs about $3000-3500 for that to be done before driving it another 150,000mi.  Belt is at the rear of the engine.     - If something happens to the transmission valve body, the special coverage is expired by mileage.  That will likely be an out of pocket expense, with zero or near zero GM participation if something happened even though its in by time.   - 2020 LM2s seem to need timing chains after 80,000mi at some point.  They fixed this end of 2020/starting 2021 model year engines.  They will usually set a P0016 I think?  There is another $8000-10,000 if it needs a chain.  The main chain is at the back, secondary at the front so the pump belt would be done at the same time if it needed chains.     - Long oil change intervals.  7,000-8,000mi on average, probably close to 0% or perhaps to or beyond 0% on the OLM.  Lots of them not at the dealer which makes me wonder how much of the oil ran through that truck was the proper Dexos D rated 0w20 oil and not just gas engine 0w20, which is not the same at all.     - Long fuel filter changes, again likely taking the fuel filter life to 0% or more.  First one went 28,603, second was done 43,094 miles later at 71,697, from there another 46,452mi to 118,149mi, and then the most recent one 37,026mi later at 155,175mi.  So counting its original fuel filter, its had only 4 fuel filters on it.  No bueno IMO.         Good news?    - It has had only two warranty trips to the dealer.  The first free service (end of December 2020 on the Carfax), and the transmission reprogram recall (end of August 2025 on the Carfax).     - Truck did a LOT of moving, so that might explain the lack of emissions related repairs like bad NOX sensors, bad exhaust temp sensors, bad glow plugs, etc.         The "emissions system checked" could just be how something was flagged for Carfax.  GM dealers have to do SAVI reports for warranty repair orders so they scan the truck.  So its possible that is there for that?
    • Thank you, @Z45!   NOTE - No all repair shop/Dealers reports to Carfax   That is my main concern.  The CARFAX looks way too clean for a 6 year old anything with 164,245 miles.  Even something known for reliability (like many Toyotas) typically has a lot more replaced, like a Nav screen, interior trim, shock/strut, or brake pads.  And surely the last set of tires (installed at ~58k miles) would be bald unless those were all highway miles.   I'm tempted to pay a local dealer to look up the VIN, but am not sure if that will be worthwhile.  Last time I did this, it was 100% useless, and I felt scammed - they noted the bumper was replaced years ago and that's it.  A 5-year old could spot the accident damage, even though nothing was on the CARFAX.   After giving the dealer a call, the truck may have a hard shift, but they have to verify with their mechanic if that's even a concern.  And I've test driven about a dozen of these now, many near Chicago, and half the trucks shift hard/odd at all throttle positions.  The ones with aftermarket lifts/larger tires shift terrible, and 3 stock trucks shifted so violently I thought the transmission valve body was going out.   At this point I'm conflicted, as I need a vehicle, and am coming up short locally.  Northern trucks in this price range tend to have either multiple owners, a lot of mods (lifts/oversized tires without re-gearing), and are generally in rougher shape.   If this truck showed up in your neighborhood for $27k and you had to purchase it sight-unseen, with the possibility of needing a 10L80 rebuild, torque converter, or rear end - would you do it?  I'm convinced most of the 10L80 trucks I test drove are broken, they can't all shift so bad, with massive flares/slipping/lurching and mis-matched downshifts like a teen driver learning stick.
    • From the spy shots, the front end does look like it's borrowing some styling cues from the Canyon. I'm more interested in the powertrain news than the screens though. If the 3.0 diesel survives into the next generation, that alone will keep a lot of current owners interested.
