2018 LT w/5.3 runs fine, no codes. I was thinking belt tensioner but I'm gonna ask if anyone may have heard this sound before. File is 30 Mg so I had to find another way to share the file.
Anyone have an opinion?
https://youtube.com/shorts/u5OBahrJPN8?
Edited by No Tyme
https://imgur.com/Gj7eO30
Just a shot in the dark without the video, seems like you think the noise is coming from the front of the engine. If so, have you checked the water pump pulley to make sure there is absolutely no play in it?
I just can't understand how to get this video up with sound. I clicked the link, which just looks like a black box to me on this page, and no sound. 30 Mg video...damn computers
Is it only there at idle or does it get louder with RPM.
Hard to tell where it's coming from in that video. Taking the belt off would be a start, if it's still there then it's maybe inside the engine or maybe bell housing.
I've heard of the clicking/popping sound at idle when it gets up to temp when a headgasket is installed backwards after a major repair but you'd really notice that sound. Installing the gasket backwards blocks a coolant flow port.
Had the truck a few years and NO work has been done to the motor. I need to get my coolant changed and new thermostat so I may have to get this serviced at a dealer
Today I verified it continues when the engine rpm's increase, as the clicking sound increases with the rpm's.
18 hours ago, mjm-1957 said:
AFM lifter getting ready to come apart.
Sadly, it does hear like lifter(s) meeting the push rods on a failed lifter.
I hope it's not that. :(
Edited by MikeBMW
  • Sad 1
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
