Glad to join the group.
Edited by GAMark
Added a picture
Welcome!  Are those factory wheels, they don't look as robust as a regular HD weight rated wheel?
 Yes, GMC wheels for the 2500/3500. When you build a GMC, you can pick them.
Edited by GAMark
Factory GMC wheels.
Shure got me confused ?????
Don't look like GM wheels.
Edited by 07HD
added comment.
Those are indeed factory wheels.
RPO code Q7J, 20 inch wheel, bright face with dark painted pockets.
    • They’re not the same wiz as 10-15 years ago.  QC has fallen pretty hard.  The XP line was never good though in the first place.    https://bobistheoilguy.com/forums/threads/wix-filter-rusted-through.386492/post-6991372   https://bobistheoilguy.com/forums/threads/i-ve-used-my-last-wix-filter.27299/   https://bobistheoilguy.com/forums/threads/looking-for-a-better-replacement-for-wix-51258.403977/   https://bobistheoilguy.com/forums/threads/convince-me-in-using-the-purolator-boss.401537/post-7420147   the forums are littered with posts and examples of not great wix filters the last couple years
    • *Your
