Hey all, going up I-75 towing the Rockwood TT, 9000 gvwr, with our 2024 gmc 2500 6.6l gas at 65mpr.
Stopped at a rest area for a few, started back on the highway about a mile, the truck jerked, disengaged tow haul mode, and went from 2200 to around 3800, noticed the check engine light on, then the air conditioner was surging. Any Ideas what caused this?
Later-
Edited by James Beyer
Well, coming home from the UP I used the manual or column shift and set up to 10 gears, without Tow Haul Mode, and it worked good.  One 75 mile stretch I averaged 9.9 mpg with cruise set at 65.  Still have to figure out what is wrong with truck but happy that manual shifting is an alternative instead of damaging the engine/transmission.
Update-was going to take truck for a scan today, but the check engine light went out, still will have it scanned to find out why,
Later-
Did you note the engine and transmission temperatures when this occurred? It could have been a high temperature protection mode. My other guess would be the 10 speed transmission valve body failure issues (hopefully not), but if temps were high while towing and it later returned to normal, it may have just been an overheat protection kicking in.
