XM Radio Question
RAYS B4U
My SS didn't come with XM Sat Radio. Could I go down to the local auto recyclers yard and pick up the receiver unit and associated parts that goes under the dash and have it work in mine?
Thanks!
Ray
Haven't done that kind of swap, but I'd say it will work but the radio will have to be programmed. Don't forget you need the XM antenna too.
Thanks for the replys. I think I'll start looing around.
I know you want to get one as cheap as you can but if the junkyard can't help you out you can get the GM setup at your dealer.
Its part number 12498768 and lists for $397.14.
I know its a little pricey but we've put a few in here at the dealership and their easy to install,its all GM,plus you get activation and the first three months free.
Thanks for the reply. :cheers: I've looked at the factory kit and if all else fails then I'll probably buy it. I saw a totaled Silverado at my dealerships body shop the other day and it had the XM antenna on it and it got me to wondering if it was a doable swap.
sorry for the bad news, but a used GM XM receiver box will not work in any other vehicle and they can NOT be unlocked to work in any vehicle other the the original host vehicle. The radio does not require any programming for the addition of a GM XM kit. I have added the GM XM kit and it works great, that is after I tried a used one and found out the hard way that they can't be vehicle swapped. Also the factory radio can not be the base AM/FM only radio (it must have the "BAND" button to accept the XM option.
    • I agree.   However, the owner's manual, suggests that a drop over full is just as bad as a drop under. (Read black and white letters only, insert no common sense.)
    • That P0700 and loss of power suggests something significant is amiss to me.   More/other codes may suggest otherwise; I would investigate those prior to spending the money to change fluid on a transmission with a bad torque converter.    The relatively sudden escalation of symptoms to me suggests that something began failing (initial shuddering experienced) and rapidly deteriorated (slipping/loss of power). Fluid condition alone wouldn't cause the sudden escalation of problems - though it might have been the cause of the deterioration up to the point of failure.
    • Stabilitrack operation is in a sense a separate/independent operation from the operation of 'traction control'. Stabilitrack is used to keep the vehicle traveling in the DIRECTION intended, it can brake independent wheels and or adjust throttle to influence the direction the vehicle is moving.   This can be illustrated by a 'fish-tailing' example. At high speeds, if the stabilitrack detects excessive yaw (the vehicle spinning like a top, it has a sensor for this), based on inputs from steering angle it determines that the vehicle is spinning out of control, and begins working to control that unintended spin. By reducing throttle input or braking specific wheels to control or prevent the spin.   The traction control works similarly using the ABS system to slow spinning wheels and thus transfer power to 'other' wheels. The goal being to achieve wheel speeds that are all in agreement with each other, the truck then assumes that since all the wheels speeds are the same no spinning is occurring. For example, launching up a wet boat ramp, there is no excessive yaw present, traction control alone can manage the wheel spin by braking spinning wheels and cutting throttle.   Stabilitrack and traction control from a hardware and software standpoint are basically one in the same, I don't remember specifically in 2004, but you couldn't get a truck with one and not the other. The switch on the dash, could turn off the traction control, but not necessarily the stabilitrack.    A confusing comment about stabilitrack vs. traction control, the same components serve both operations, but marketing could advertise them as two separate features.    The AWD system is another separate system entirely, in addition to the other two, it uses the same wheel speed inputs but can also vary the transfer case clutch application to direct some power to the front axle, working in conjunction with the traction control to bring wheel speeds together.   The power split will never be greater than 50:50, the same as 4-high. It will never direct MORE power to the front axle than the rear.
    • Not based on the new photos I'm seeing.  Car and Driver posted additional photos that shows an auto stop start button left of the steering wheel.
    • Car and Driver is reporting wireless CarPlay WILL remain, and they posted several additional photos, including a left knee shot, but the only hard buttons there are e-brake, auto start stop, tailgate and cargo light.  Also definitely looks like High Country and ZR2 get micro fiber on the center of the console lid and the ZR2 possibly also on the seats.
