Silverstars from Sylvania...like them?
Hi guys...read a few posts on sylvania silverstars recently...let me here some opinions from some of you that have had them a while. Do you have any pics to show how they look at night? How long did it take to put them in? Are you happy with your lamps, was it worth the bucks? Have they lasted well? I assume these are OK for our trucks as far as the housing is concerned...in other words, they do not melt anything, right? Finally, if I replace them I will more than likley do High (9005ST), Low (9006ST), Daytimes (4114L) and Fogs (9415ST)...what part numbers should I get (I notice there are a few different options on the Sylvania site), and is it necessary to replace all of these...? Thanks for the info, later, :D:cheers::D
I don't have any yet, but I'm about to buy some. A lot of people on here like them...I haven't read too many bad things about those bulbs. I wouldn't bother with the DRLs though...
I changed to them, low bean so far, i love them.
lights up road great , sorry no pic
I put them in my 99 Suburban because the stock headlights just didn't seem that bright anymore. Anyway I only did the low beams and they are very nice. I did find after installing them and using the truck at night part of my problem might be adjustment. So I still need to adjust the headlights. The drivers side seems to be pointing down more than the other side. Also, when I turn on my bright lights they just seem yellow now compared to my low beam silverstars.
I have had them for a while and like them. I replaced the lows only on my 98 and the difference was incredible. After replacment, I polished my lenses with Flitz to make them clear again, now the difference is night and day.
Ive got the Hi and Lo bulbs and love them! What a difference, I wish they came stock. When I flash my Hi beams all four light up and wow, lots of white light. Havent had a chance to take a road trip through the desert at night yet to see the Hi's in action but I know they are way better than the stock Halo bulbs.
Go get them, youll like them.
I have had them for like 3 yrs??? Since they first came out. I had one burn out after a yr so I just put the original in until I changed both out about a month ago. I also had the fog light bulbs. I had one burn out after a month. I contacted sylvania and they sent me a pair. Havent put those in yet but i did like them. I would say they are worth it and sylvania does stand behind their product.
Also a head up murrays runs a buy one get one 1/2 off at times. Walmart sells them in 2 packs also for like $6 cheaper than buying them single at most place
Just had to replace the driver's low after about a year and 3/4. Love them, great light and look. I've got the lows, highs, and fogs. Point to note: if you go with them, don't touch the glass during the install or you can cause early failure.
You might try going to the search function and putting in silverstars.
Then reading the nine pages of past postings. It's and intersting read.
There are bulbs out there that will increase your visibility for less money.
I don’t like them as a replacement performance bulb. They look nice for what they are (an inexpensive HID looking alternative), but in my situation, in order for them to illuminate the road any better than my stock lamps; I had to re-aim my headlights to a degree that irritated oncoming traffic. In the stock position they looked cool but did nothing special when it came to lighting up dark, two lane rural highways that are also used by deer and coyotes. In the city where street lighting is abundant; they performed just as fair as our stock headlights.
Personally, my biased opinion rates them a 7 for looks, a 5 for performance, and a 5 for value. Once you have true HID like I have on my Sub’s, everything else is a far cry from performance lighting.
your HID "x2020 kit" has Silverstar highbeams in it.
so you must notice a small difference.
I'm up here in new england and I love mine on the cold rainy nasty nights because I can see them critters easier than with my lame stock yellow beams.
they are cheap money and ARE an upgrade form stock.
I have had great luck with them and never had to reaim to get the proformance needed.
I've had em in for about a year now...and love em. Definitely an improvement from stock, for short money. Obviously they don't compare to HID's...
Hi Mike –
Depending on the vendor, it’s an option to have the Silverstars included as the high beam. I actually ordered mine without the Silverstars due to my past experience with them. Don’t get me wrong – I think SS’s are pretty cool for what they are but they didn’t help me in my situation / application.
Actually, the X2020’s won’t fit a 2004 truck (up to 2002, I think). To solve the problem on my 2003 DMAX, I now use a Kennedy Wiring Harness that gives me the high and low beams together.
Install a pair of Hella "Black Magic" lamps out front and that will solve your problems. I have a set and LOVE them when me and the "critters" are the only ones on the road. They have a "eurobeam" design which is like a narrow wide beam combined with a very long range pencil beam.
Like I said, I love mine, would not go without! :P
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
