ABS light came on
Mark_in_Tulsa
Well yesterday I started up my truck 5 min after I just turned it off from after driving 5 miles. And I noticed my ABS light was on. So I turned it off and started it up again, and sure enough it popped up again.
Well the truck braked fine, I even tried to lock them up at 25mph, and it stopped hard like it should with out skidding.
So I thought it was just maybe a faulty code, So I took it to a local brake shop, for them to check the code. And 30 min later the guy tells me my ebcm, abs brake pump or known as the bpmv (brake pump motor valve) needs to be replaced. The EBCM is not sending out any voltage.
The guy tells me with parts and labour, and re-bleeding the brakes....etc it will be close to 3 grand. Well after I soiled myself, I realized that I still have 2000 miles left on me ext. warranty, but with a 200 deductible.
The guys haven't started working on it yet, because the warranty place is sending out an inspector to make sure the shop isn't BS'ing them, sometime in the next 48 hours. But luckly my warranty covers a rental truck.
Is this something that happens often? What would cause it to go out? Only mods are 285 tires from 265 tires, in a 2002 Silverado ext. cab z71 5.3.
I would appreciate anyone's input or spare 100 bills.
Well then inspector guy came out, and he saw the ABS light, and they cleared the codes in front of him, and they went out for a test drive, so the inspector could see the ABS light come on, and of course now it won't come on.
So the inspector said he would be back tomorrow, and that they have all day to get the ABS light back on.
So now I'm going to get ripped off for my rental truck, that my warranty covers if my truck isn't really broken. Obviously they won't cover my fees for a rental if there is nothing wrong with my truck.
Anyone have any ideas what would make the ECBM go in an out like that.
Could be simply moisture in one of the electrical connectors. Did they unplug the connectors and clean them?
There are a few relays internal to the EBCM that can stick intermittently. I would tell the inspector that it is an intermittent condition and you would like to know what caused the codes that were there before he cleared them. Ask him if it comes on next week, is the warranty company going to reimburse you for the rental car for this visit? Get it in writing.
Thanks guys for the help. Well my baby has been driven for about 100 miles. With lots of brake slamming, on and off road. We can't get the light back on.
From what I understand the EBCM, and the brake pump motor, neither were showing any voltage or signal. But now everything seems to be fine.
I have all of their paperwork from their ALLDATA software. It looks like the error code is DTC C0266.
    • 3.47 Kroger’s in Montgomery Tx
    • I can relate. 3 years ago I did that on my Avalanche. I was sore for a week. The only maintenance I do myself now is drop and fill on the transmission on my Honda’s. It’s just too easy. My yard work with my walks in the morning will be enough now I passed 70. The contributing factor is the heat in Texas. You just have to pace yourself.
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
    • I turned 72 today. My day began with a trip to the pharmacy to pickup meds for me and the dog and then a stop at my chiropractor before heading home. Once home I started the job of replacing the rear brake pads and one rotor on our 2018 Silverado which will probably end up taking me 3 days to finish, gotta pace myself you know. Sometimes I question myself on why I still do most of my own repairs but if I wasn't then it's more than likely I would be sitting in front of the TV all day. It seems like the list of things I need to do gets longer no matter what I accomplish. I'm not complaining but being retired was so much easier when I was 62.   Peace
    • google "bathub failure curve". Basically, any part of the vehicle can fail at any time.  It starts off as being more likely (early failure), then the failure rate goes down (but does not go to zero), then it goes up over time because it wears/ages out.
