Ford F100
unit731
Automtive News
5/19/2008
Amy Wilson
and Robert Sherefkin
Automotive News
May 19, 2008 - 12:01 am ET
DETROIT — Ford Motor Co. is developing a lightweight, more fuel-efficient pickup truck to slot in below its flagship F-150.
The new pickup truck, code-named P525, is being engineered on the F-150's platform. But it will be lighter and slightly smaller, supplier and industry sources told Automotive News. The pickup is scheduled to go into production during the first half of 2011 at Ford's Michigan Truck Plant in Wayne, Mich., sources said.
Ford may call the truck the F-100, bringing back a nameplate used for decades beginning in the 1950s. The new truck is larger than the Ford Ranger. But it might help take the place of that compact pickup, which could go out of production in 2009 when Ford's Twin Cities plant in St. Paul., Minn., closes. Ford hasn't said whether the Ranger will continue.
The new pickup is in Ford's cycle plan, sources said. But it has not received final approval.
Mark Fields, Ford president of the Americas, would not confirm plans for a slimmed-down truck in a recent interview. But he did acknowledge that Ford must take weight out of its pickup trucks to meet new fuel-economy standards.
"When you see what the F series makes up in terms of the composition of our vehicle lineup, clearly that's one area we really have to focus on," Fields said.
The new pickup truck will have unique sheet metal and innovative storage space, sources said. It could be powered by a version of Ford's new V-6 EcoBoost engine, which uses turbocharging and gasoline direct injection.
Its not like its a new thing even though the concept they are trying to reach will be newly achieved...
What I am trying to say that I think that Ford used to have a F100? At least I thought that there was one...
I have to agree. It will probably be a ranger replacement, or it will be something to directly compete with the Durango. I'm thinking large Ranger here.
EDIT: Im a dumb a**. I said Durango. What I meant was Dakota.
Finally they see the light. This is the direction of the future, lighter, smaller more fuel efficient trucks.
We have these already. They are mid-sized trucks.
Looks like a direct compete with the Colorado and Canyon since there getting the 5.3 motor in 2009 Midyear.
I'm not sure, but from the way the article describes the "F-100", it will be too large to directly compete with the Canyon/Colorado twins.
I may be wrong, but that was my interpretation of the article. That said, it probably will steal sales from the twins, but I think it would hurt Dodge and family more than it would GM.
I don't think it will go over real well except in the I buy a truck to look cool crowd. Other wise it won't be truck enough to do truck work.
I do think my oinker of truck could stand to shed a few pounds off its 5600 pound curb weight.
Do any of the 'smaller' trucks have a 4x8 bed?
That's the whole point of the full size truck - at least in the beginning. Plywood and sheetrock.
I don't know how they can manufacture a full size truck and make it very much lighter and still do what a truck is supposed to do. And will this truck retail for more or less than a regular F150? From the little that I know, the lightweight materials cost more. So is this going to be a more expensive truck that gets better gas mileage?
The Ford Marketing people may be looking and finding people who are willing to pay more for a better gas milegage full size truck.
Or is this going to be an entry level no frills truck that does sell below the F150? I personally would prefer this angle.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
