Vin Check Please
2GCEK19T6Y119125 please and thanks. the handwriting was sketchy, but it should come back to a blue 1500 ext cab somewhere im guessing in the 03-04 range
no, that comes back as a 2006 PONTIAC SOLSTICE. Get the last 8 of the vin and that should work
he didnt produce a complete check. he'll get his cookie when he supplies the info i want. lol wtf this blows. i thought that guy was kinda shady. now that i look at it i only have 16 numbers/letters. dont i need 17?
Yep,We need either all 17,or the last 8 digits.
i got it! 2GCEK19T6Y1119125 i skipped a 1 towards the end there. thanks again
edit: the cookie offer still stands
Something major happened around 16,000 miles,She had a new engine and catalytic converter installed,But all the recalls have been done.....
GM Vehicle Inquiry System
Summary
VIN : 2GCEK19T6Y1119125
VEHICLE INFORMATION
Merchandising Model : CK15753 -2000 SILVERADO LS 1500 PICKUP
Warranty Start Date : 09/08/1999
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer :
IVAN GANDRUD CHEVROLET, INC.
PO BOX 487
GREEN BAY , WI 54305-0487
(920) 468-6800
Selling Source : 13 - CHEVROLET
Site Code : 18667
Business Associate Code : 111778
Service Contract : No
Branded Title : No
Warranty Block : No
PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 00024 FRONT BRAKE HOSE ABRASION N/A *Closed*
RC 00093 FRONT BRAKE PIPE CONTACT WITH BODY CROSS SILL N/A *Closed*
RC 02029 AIR BAG SENSING DIAGNOSTIC MODULE (SDM) N/A *Closed*
RC 05068 FRONT WHEEL SPEED SENSOR CORROSION N/A *Closed*
RC 06019 TAILGATE SUPPORT CABLE REPLACEMENT N/A *Closed*
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 09/08/1999 466 miles 09/08/2002 36466 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 09/08/1999 466 miles 09/08/2005 100466 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 09/08/1999 466 miles 09/08/2007 80466 miles
36/36000 FEDERAL EMISSION 09/08/1999 466 miles 09/08/2002 36466 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
09/25/2006 279577 # V1462 - 06019 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 106357 miles
11/14/2005 261003 # V1410 - 05068 - INSPECT WHEEL SENSOR (INC. CLEANING) 93378 miles
09/11/2002 191785 # V0609 - INSPECT BRAKE PIPE & INSTALL SPACER CLIP 51491 miles
09/03/2002 191210 # V0881 - 02029 REPROGRAM SDM 50982 miles
12/20/2001 174832 # B4023 - HINGE, FRONT DOOR (WELD ON) - DOOR SIDE - LEFT UPPER - REP 38640 miles
12/20/2001 174832 # N0528 - BULBS, LAMP - EXTERIOR - REPLACE 38640 miles
06/11/2001 161629 # J6441 - EVAPORATIVE EMISSION CANISTER VENT SOLENOID VALVE REPLACEM 31265 miles
06/11/2001 161629 # E7420 - STEERING SHAFT REPLACEMENT 31265 miles
04/13/2001 157733 # J5490 - THROTTLE BODY ASSEMBLY REPLACEMENT 28260 miles
11/13/2000 147999 # J5645 - INJECTOR, FUEL - DIAGNOSIS 21451 miles
07/13/2000 139655 # J1840 - ENGINE, UNIVERSAL - REPLACE 16117 miles
07/13/2000 139655 # J6372 - SENSOR, OXYGEN (ENGINE CONTROL) - REPLACE 16117 miles
07/13/2000 139655 # L2300 - CONVERTER, OXIDATION CATALYTIC - REPLACE 16117 miles
07/13/2000 139655 # Z7901 - 1-DAY COURTESY TRANSPORTATION 16117 miles
07/13/2000 139655 # V0486 - 1999-00 CV & GMC C/K 1/2T P/U - INSTALL NOTICE LABEL 16117 miles
08/10/1999 119125 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
© 1998-2005 General Motors Corporation. All Rights Reserved.
Claim History
CLAIM HISTORY
Repair Order Date : 09/25/2006 Repair Order Number : 279577 Odometer Reading : 106357 miles
Serviced By : PHILLIPS CHEVROLET INC
33 W LINCOLN HWY
FRANKFORT, IL 60423-1399
(815) 469-2323 Selling Source : 13 - CHEVROLET
Site Code : 11437
Business Associate Code : 113225
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
10/03/2006 731 01 # V1462 - 06019 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 88980510 - CBL-E/GAT
Repair Order Date : 11/14/2005 Repair Order Number : 261003 Odometer Reading : 93378 miles
33 W LINCOLN HWY
Site Code : 11437
11/22/2005 641 01 # V1410 - 05068 - INSPECT WHEEL SENSOR (INC. CLEANING)
Repair Order Date : 09/11/2002 Repair Order Number : 191785 Odometer Reading : 51491 miles
33 W LINCOLN HWY
Site Code : 11437
09/27/2002 312 01 # V0609 - INSPECT BRAKE PIPE & INSTALL SPACER CLIP 15070819 - BRACKET
Repair Order Date : 09/03/2002 Repair Order Number : 191210 Odometer Reading : 50982 miles
33 W LINCOLN HWY
Site Code : 11437
09/10/2002 307 01 # V0881 - 02029 REPROGRAM SDM N/A
Repair Order Date : 12/20/2001 Repair Order Number : 174832 Odometer Reading : 38640 miles
33 W LINCOLN HWY
Site Code : 11437
02/26/2002 251 01 # N0528 - BULBS, LAMP - EXTERIOR - REPLACE 12450108 - BULB
02/08/2002 246 01 # B4023 - HINGE, FRONT DOOR (WELD ON) - DOOR SIDE - LEFT UPPER - REP 15768685
Repair Order Date : 06/11/2001 Repair Order Number : 161629 Odometer Reading : 31265 miles
33 W LINCOLN HWY
Site Code : 11437
06/22/2001 180 01 # J6441 - EVAPORATIVE EMISSION CANISTER VENT SOLENOID VALVE REPLACEM 15759042 - HOSE
06/22/2001 180 02 # E7420 - STEERING SHAFT REPLACEMENT 26085548
Repair Order Date : 04/13/2001 Repair Order Number : 157733 Odometer Reading : 28260 miles
33 W LINCOLN HWY
Site Code : 11437
04/24/2001 163 01 # J5490 - THROTTLE BODY ASSEMBLY REPLACEMENT 17113665
Repair Order Date : 11/13/2000 Repair Order Number : 147999 Odometer Reading : 21451 miles
33 W LINCOLN HWY
Site Code : 11437
11/17/2000 118 01 # J5645 - INJECTOR, FUEL - DIAGNOSIS 12345104 - DETERGENT
Repair Order Date : 07/13/2000 Repair Order Number : 139655 Odometer Reading : 16117 miles
33 W LINCOLN HWY
Site Code : 11437
08/29/2000 95 01 # J6372 - SENSOR, OXYGEN (ENGINE CONTROL) - REPLACE 12562943 - SENSOR
08/11/2000 90 01 # J1840 - ENGINE, UNIVERSAL - REPLACE 88893291 - ENGTLM7GW
08/11/2000 90 02 # L2300 - CONVERTER, OXIDATION CATALYTIC - REPLACE 15036169 - CONVERTER
08/11/2000 90 04 # Z7901 - 1-DAY COURTESY TRANSPORTATION
08/11/2000 90 05 # V0486 - 1999-00 CV & GMC C/K 1/2T P/U - INSTALL NOTICE LABEL
Repair Order Date : 08/10/1999 Repair Order Number : 119125 Odometer Reading : 0 miles
Serviced By : IVAN GANDRUD CHEVROLET, INC.
PO BOX 487
GREEN BAY, WI 54305-0487
(920) 468-6800 Selling Source : 13 - CHEVROLET
Site Code : 18667
08/13/1999 985 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Vehicle Build
VIN 2GCEK19T6Y1119125
VEHICLE BUILD
Gross Vehicle Weight Rating : 2906 kg (6408 lb)
Order Number : BRSVTT
Build Date : 08/10/1999
Build Plant : 2Y153
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AE7 - SPLIT BENCH RECLINING FRT SEAT
AJ1 - DEEP TINTED GLASS
AM7 - FOLDING REAR SEAT
AU0 - KEYLESS REMOTE DOOR LOCK AND TRUNK OPENER
AU3 - POWER DOOR LOCK SYSTEM
A31 - POWER WINDOWS
B30 - WHEELHOUSING & FLOOR CARPETING
B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR KEYED FLOOR MATS
B85 - BRIGHT BODY SIDE MOLDINGS
C60 - AIR CONDITIONING
C7H - 6,400 LB GVW RATING
DK7 - INTERIOR CUSTOM ROOF CONSOLE
D48 - ELECTRIC EXTERIOR MIRRORS
EVA - EVAP EMISSION REQUIREMENT
E63 - FLEETSIDE BODY
FE9 - FEDERAL EMISSION
FK2 - TORSION BAR SPRING ADJUSTMENT
FK3 - TORSION BAR SPRING ADJUSTMENT
GT4 - REAR AXLE - 3.73 RATIO
JC5 - 4 WHEEL POWER DISC BRAKES
K34 - ELECTRONIC SPEED CONTROL WITH RESUME SPEED
K68 - 105 AMP DELCOTRON GENERATOR
LM7 - VORTEC 5300 V8 SFI GAS ENGINE
M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NF2 - FEDERAL EMISSION SYSTEM
NP5 - LEATHER WRAPPED STEERING WHEEL
NP8 - 2-SPEED ACTIVE TRANSFER CASE
OSG - OSHAWA ASM PLANT
PF9 - WHEEL-16" CAST ALUMINUM
QNL - P245/75R16 ALS WOL TIRES
SLM - STOCK ORDERS
UN0 - AM/FM STEREO W/CD PLAYER
UQ3 - ENHANCED AUDIO SPEAKERS
VB3 - CHROMED REAR STEP BUMPER
VG3 - FRONT DELUXE CHROMED BUMPER
VXS - COMPLETE VEHICLE LABEL
V22 - DELUXE FRONT APPEARANCE
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XNL - P245/75R16-109S ALS WOL TIRES
X88 - CHEVROLET CONVERSION
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
YD6 - BASE REAR SPRING
YE9 - SILVERADO
YNL - P245/75R16-109S ALS WOL TIRES
ZNL - P245/75R16-109S ALS WOL TIRES
ZY1 - SOLID PAINT
Z83 - SOLID SMOOTH CHASSIS PACKAGE
1SB - OPTION PACKAGE 02
1SZ - PREFERRED EQUIPMENT SAVINGS
12D - GRAPHITE CUSTOM CLOTH
12I - GRAPHITE INTERIOR TRIM
39U - INDIGO BLUE METALLIC
6WY - FRONT SPRING
7WY - FRONT SPRING
Vehicle Component
Vehicle Component
Component Code : 10 - ENGINE ASSEMBLY
Source Plant : W - CPC/DDA ROMULUS, MICHIGAN
Part/Num Broadcast : FHB Traceability : 992166362
Date Scanned : 08/10/1999 Time Scanned : 04.38.00 Scan Station : 04
Component Code : 35 - STEERING COLUMN - SIR SYSTEM
Source Plant : S - SAGINAW DIVISION SAGINAW,MI
Part/Num Broadcast : SAR Traceability : 341942179
Date Scanned : 08/10/1999 Time Scanned : 00.14.00 Scan Station : 10
Component Code : 50 - INSTRUMENT CLUSTER
Source Plant : 3
Part/Num Broadcast : CDK Traceability : CDK
Date Scanned : N/A Time Scanned : N/A Scan Station : N/A
Component Code : 60 - TRANSFER CASE (4 WHEEL DRIVE)
Source Plant : N
Part/Num Broadcast : PU Traceability : 0AA583500
Component Code : 61 - TRANSMISSION
Source Plant : Y - HYDRAMATIC TOLEDO, OHIO
Part/Num Broadcast : 0KCD Traceability : 25738894
Component Code : 63 - FRONT AXLE/FRONT CRADLE WITH FRONT HUB ASSEMBLIES
Source Plant : G
Part/Num Broadcast : ZXN Traceability : L297672
Date Scanned : 08/10/1999 Time Scanned : 05.15.00 Scan Station : 05
Component Code : 65 - REAR AXLE ASSEMBLY
Source Plant : G - SAGINAW DETROIT, MICHIGAN
Part/Num Broadcast : BC4 Traceability : 155409
Date Scanned : 08/10/1999 Time Scanned : 05.12.00 Scan Station : 07
Component Code : 86 - ELECTRONIC CONTROL MODULE (ECM)
Source Plant : 9
Part/Num Broadcast : CYCB Traceability : 29217L2DV
Date Scanned : 08/10/1999 Time Scanned : 08.32.00 Scan Station : 05
Component Code : 87 - BODY CONTROL MODULE
Source Plant : M
Part/Num Broadcast : 1990 Traceability : 29215JX26
Component Code : 92 - BRAKE PRESSURE MODULATOR VALVE ASSEMBLY
Source Plant : K - KELSEY-HAYES JASPER, INDIANA
Part/Num Broadcast : 0569 Traceability : 00048649
Date Scanned : 08/10/1999 Time Scanned : 05.17.00 Scan Station : 09
Component Code : AB - IR-MODULE ASM-INFLATOR
Source Plant : I - INLAND
Part/Num Broadcast : 4248 Traceability : 2TDX9KJ
Date Scanned : 08/10/1999 Time Scanned : 05.33.00 Scan Station : 11
Component Code : AD - IR-SENSOR-FORWARD
Source Plant : H - HAMLIN INC, LAKE MILLS WISCONSIN
Part/Num Broadcast : 6305 Traceability : 00LGHL
Date Scanned : 08/10/1999 Time Scanned : 00.03.00 Scan Station : 12
Component Code : AL - IR-MODULE ASM-I/P
Source Plant : Q - RIMIR MATAMORS MEXICO
Part/Num Broadcast : 2834 Traceability : 2TFS6KC
Date Scanned : 08/10/1999 Time Scanned : 00.14.00 Scan Station : 01
Component Code : AS - SENSING DIAGNOSTIC MODULE
Source Plant : K - DELCO ELECTRONICS KOKOMO,IN
Part/Num Broadcast : 5462 Traceability : 3921028N1
Component Code : CB - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 199 Traceability : 0210627
Date Scanned : 08/05/1999 Time Scanned : 16.14.00 Scan Station : N/A
Component Code : CP - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 133 Traceability : 1014994
Date Scanned : 08/10/1999 Time Scanned : 00.27.00 Scan Station : N/A
Delivery Information
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 09/08/1999
Delivery Type : 015 - RETAIL LEASE/INDIVIDUAL
Delivered Odometer : 466 miles
Delivering Dealer :
PO BOX 487
(920) 468-6800
Delivery Selling Source : 13 - CHEVROLET
Delivery Site Code : 18667
chocolate chip ok? lol wow i thought the deal sounded too good to be true. some guy was askin 9k for the truck. the last service was almost 2 years ago with 106xxx miles. probably hittin 120 now. i think ill pass on a high mileage truck with that many service records
Yeah but remember,This is just work that was covered under warranty or a recall,It won't show "normal" maintenance done like oil changes,tire rotations,tune-ups,etc,.
And actually seeing all this work done should help in the fact that you know the guy kept up on the recalls and such,If you can get the truck for a decent price I'd buy it!! I wouldn't let the mileage scare you,If you can get it for the "RIGHT PRICE"!!
