I just replaced mine on my 2006 sierra also...it is at the end of the fuel tank towards the front of the truck...you have to relocate the breather canister when you replace it...if you need more info let me know I just went through the same thing....I am new at this forum also so I hope you are better than me at navigating through this and send me a message...
is it easy to replace
Just wanted to give this thread another thumbs up. :( I have a 2006 GMC Sierra Crew Cab Z71 and was getting codes P0449 and P0455. Replace my canister with ACDELCO 2142149 from Rock Auto (less than $20), along with some rubber heater hose and clips (less than $5). Installation was easy and the check engine light turned off the next day.
Thanks for the great info. :P
Just wanted to post and say "Thanks" to odayflor and everyone who contributed info on the repair for code po449, at least it did work for my truck!!
I went to my local Advance Auto Parts and bought the AC Delco part # 214-2149 which is the same exact part that was originally on my '06 1500 crewcab!
Cost for the solenoid was $23, plus the piece of heater hose & 2 clamps.
Guess I'm curious as to why GM wants to "update" with remote filter, what is the advantage of it?
Funny thing too, after completing the swap of the solenoid, started up the truck, rolled it down the ramps , let it run for a few minutes to move the ramps out of the way and got back into the truck to park it, the engine light was off and has been ever since!!
Again, thanks for the help!! :thumbs:
WELCOME!!!!!!!!]
Just wanted to give this thread another thumbs up. :driving: I have a 2006 GMC Sierra Crew Cab Z71 and was getting codes P0449 and P0455. Replace my canister with ACDELCO 2142149 from Rock Auto (less than $20), along with some rubber heater hose and clips (less than $5). Installation was easy and the check engine light turned off the next day.
Thanks for the great info. :)
Ian -
I have the '06 Chevy version of your truck (crew cab Z71) - but I can't seem to locate the canister. I've looked at the pics that have been posted here - crawled under the truck yesterday (it's cold in Indy right now) but no luck. Where was it located on your truck? I think if I can physically "see" it, life will be a bit simpler from there. Hopefully it isn't mounted somewhere on top of the tank?
Thanks in advance.
WELCOME!!!!!! Glad it helped....Although not a single GM employee agrees with us on this
Thanks to everyone here i have ordered the part. I will let you know if it works on my truck as well.
I have an 06 crew cab. once i order the part how do I know where to run the hoses? everyone is talking about purchasing the extra hose but where the hell does it go? lol did i miss a post?
I have a 1999 sierra 5.3 and this vent valve fit on without any trouble at all. even the stock hose fit right up...only thing was because this valve is a bit bigger the bracket needed a slight tweek (just bend it a bit).
Don't think twice about using this part number...it's a no brainer fit.
Hi guys, Im new to the site. My engine light came on this morning and coded p0449. Im hoping the AC Delco part will work on my 03 Silverado 4.8? Can you guys help me out? 1500 4x4 reg. cab. Thanks.
    • I find it amusing the OP doesn’t realize this threads heading includes several engines. He should have posted in the off topic section if he wanted a more narrow focus. I really appreciate and find amusing that he actually pointed out one of my many vehicles. The Odyssey. That happens to use 0-20 oil. I love pushing his buttons.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
