Stuck In 4low
matt123
My truck has always had problems going from 2 to 4 and high to low. Normally it goes into 4 wheel hi no problem but after about 1 min of driving the service 4wd light comes on and i have to shut it off and restart the truck and then i can shift the transfer case fine. I put it in 4low for just a second, never went off road and i cant get it out no matter what i try, the 4wd switches dont even light up. I had to drive home about 10 miles in low range going almost 30.
I crawled under the truck to find i think a blue wire not hooked to anything and a 2 wire connector haning there that dont seem to go to anything. My truck is a 99 silvy 2500hd 6.0, the pan on the tranny has writing from like a junk yard and i'm sure has been replaced, how can i tell if its a 4l80E? I wanna be sure that they didn't put a 4l60e in it.
Please help, i dont know what to do. I've always been a toyota guy, i never worked on a chevy, all this electrical stuff is new to me. A wiring diagram to the tranny/tcase may be helpful if some one can scan one or something.
To get out of 4lo you could pull off the encoder to expose the shift stem and get a wrench on it to shift it manually. Easy to take off; pull off the front driveshaft and then just 3 bolts and 2 wire plugs. That's how it was on my '00 1500. As for fixing it properly it could be a few things and I'm not the right guy to help diagnose. With mine it was the buttons the first time and the encoder the second time. Those things seem to always be causing problems. Sometimes I wish I still had my '79 Ford.
Mine can be difficult at times. It's the push buttons in the dash instead.
Well i went out the next day to pull it in the garage and take a look at it but when i started it i noticed all the 4x4 lights came on and it shifted right into 2wd. So i'm thinking it is just the buttons acting up.\
Thanks for the replies.
Also on a side note i got my first ever ticket today.... Coming home from xmas there wasn't really any traffic and i just didn't really care about anything at the time... Went through a speed trap thing at 97mph.... $427 ticket.... I'm really glad i dont have a tunner yet cause i know that i would've raised the govener and at 99+ mph its a $1200 min. ticket. Hopefully i will learn from this and it wont get reporded to insurance
Find a "TICKET FIXIT" lawyer.
They can cut a deal with traffic court and keep it off of your driving record.
Matt,
Glad your transfer case is working. You should track down the loose wire and connector. There are plugs on upper areas of the transfer case as well as the front diff. and the trans has some plugs as well. There's also a fuse in the panel on the side of the dash when you open the drivers door.
Get your kicks in the dirt where there's no cops for tickets and nobody else to hurt. A 4x4 ain't too good to be doing a hundred MPH in on the street. Hate to hear about a big accident.
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
    • Oil and filter threads are always a good time.  Especially when the BITOG discussion forums are cited as a definitive, technical source.    Countless single-data-point examples of why something is the best ever, or will destroy your engine... "they changed the shade of blue on the filter can, use at your own risk!"... "I've heard they changed the design to only have 64 pleats, total junk!"... "They're hidin' the NOACK data from us!  I wouldn't use that stuff in a cement kiln!".... "There was a guy who cut open Filter X (with a sawzall) and the anti-drainback valve was orange!  It used to be black!  Chinese junk!"   Good stuff.
    • I finally bit the bullet and installed a set of Bilstein 5100's on my 2024 Silverado 2500HD. My truck had about 75,000 miles and I've always felt the factory shocks were less than forgiving. So Bilstein 5100's are the most common go-to replacements. I personally have installed them on many trucks....2002 Silverado 1500, 2014 Silverado 1500, 2017 Chevy Colorado, 2019 GMC Canyon, 2022 Silverado 1500...now my 2024 Silverado 2500. I will eventually put them on my 2021 GMC Yukon as well. Great all around shocks.    Below is my video tutorial installing them on my 2500. As a bonus, for recently hitting 20,000 subscribers on my YouTube channel, I teamed up with Nick Scovel Jr at Scovel Motorsports to create a giveaway. Details are in the video description. Like, Subscribe and Share
    • Raven    About 2 more weeks and this Mirage will be two years old and already packing 54K miles. The CVT has settled in and is outperforming my expectations. The engine in quite, smoot for a three pot and very economical to fuel. Life time result to date is a stunning 52.44 mpg with a median tank of 52.74 mpg. Given the number of miles I drive and the cost of fuel lately this buy has turned out to be quite the winner in this stable.       She is also quite the teacher. Nice thing about a car that gets this type of milage is that you see the results of minor changes with the change instead of having to average a months worth of gas tickets to filter out the tank to tank scatter. Those lesson apply to everything in the fleet and everything I've done to the pack works with this one as well.   EPA numbers for this car:     This example is running 42% over the government values!!!!  😱    I am really enjoying this car. Can't even hear the laughing of those that thought this a 'dumb/disappointing buy".
