Question: Dl8 To Dl3 Mirrors
I've got an LT with what they call a "true truck" interior. I don't care about the power folding part - all I want is the signal, heat and power adjustment. Can I manually fold the DL3 mirrors in like the above guy asked? You know, just push them inwards flat against the truck
Yes, I have manually folded in the ones on my Tahoe and Silverado with zero issues and they felt the same as the old DL8's
Same here. Everything works except the Auto-Dim and Power Fold on mine which is no big deal because I never had it to begin with.
  • 3 weeks later...
  • Replies 59
...to anyone who's performed this upgrade and doesn't have power-folding operation after the fact, do you still manually fold your mirrors? if so do you notice them not locking into position? during the winter i go through automatic car washes so i need to be able to fold my mirrors in with no repercussions...
This is what I'd like to know. I found a pair of painted and unused DL3 mirrors for my 2011 Silverado, and want to know the following:
  • I've got an LT with what they call a "true truck" interior. I don't care about the power folding part - all I want is the signal, heat and power adjustment. Can I manually fold the DL3 mirrors in like the above guy asked? You know, just push them inwards flat against the truck.
  • They appear to be in a folded-in state but are not mounted on the truck. I've pulled them out as hard as I dare without breaking them, but they're firmly in the "folded-in" state. How do I get them in a normal state (out) without an electrical connection for the motor?
Thanks for your help. I'd like to have them in a normal state, so I can take them to my local paint shop to paint 'em shiny black, then be able to mount them on the truck.
M
like Ryan and Daryl said, you can still fold them in without issue. i folded mine in several times over the course of a couple winters and there was never a problem.
Could a toggle switch be added somewhere else on the dash or door to power the folding option? I have been thinking about this for a while and I'm now sure why it wouldnt work, but I'm not an electrician and I didnt sleep at a Holiday Inn Express. I guess I'm a little different than the rest of they guys that are doing the upgrade in that I want the power fold and dont care about the turn signal. It would be great if the toggle type switch hooked up to the battery would work. Any thoughts?
I am not sure what code I have. They are manual fold and heated. The turn signal I might add but I do not like what GM did. I want my signal on the bottom visible from teh front side and rear. I might have to mock up a piece and start cutting but I did see somewhere that I can just add turn signal glass/led. The kit was like 60. It was stock GM glass not some stick on LED strip/arrow. I want the power fold tho
Just buy the door switches with the folding button and replace them. Much easier and cleaner look
Can he do that? I've heard that depending on the year like say a 2011 like mine that the switches won't work?
To do that I would need to buy new wiring harness for both doors as well as the switches. Then I have to go to the dealer to have all the new switches programmed.
  • 7 months later...
I just got a 2012 Sierra SLE and I really wanted to do this swap. I bought the Dl3 mirrors both switches and was ready to go BUT when I pulled my switch panels I find different connectors. There is no way I can use the new switches. Then I did more research and find that I will have to change out the door harnesses. Has anyone come up with the part numbers fo these?
changed my 2006 Silvy from DL8 to DL3. bought mirrors from craigs list and switch from someone on the site and had programed by dealer. all in all 250 bucks when said and done.
Now selling my DL8 mirros and switch as a set to recoup some cost with switchout.
Don't know I'd you already got the answer but I actually did this back in June and all I did was get the dl3 mirrors driver door switch and passenger door switch and made sure they both were off of a dl3 truck. Then I installed them everything worked perfectly auto tilt and dimming mirror works w/ power fold and puddle lamps. Basically everything went flawless and that's all you need I'll post a video up
Later when I'm home. The truck was a 08 Yukon btw
  • 4 years later...
[email protected] has all of the answers for converting dl8 to dl3 mirrors. He's done all of the research. He surley made the process for mine so simple.shoot him an email and he'll be happy to help you with your swap
  • 10 months later...
On 1/9/2009 at 9:52 AM, Porter_ said:
i searched 'DL3' and read until my eyes bled but didn't find an answer to this specific question. i want to upgrade from DL8 to DL3 mirrors. my truck does not have door modules so it's my understanding that i won't be able to use the power fold feature but i will gain the integrated turn signals, which is all i care about. my owner's manual says something along the lines of: "if power-folding mirrors are accidentally folded manually, they may not re-lock into position and could vibrate out of place when driving on the highway. to correct this, use the power-folding buttons located on the driver's door to re-position the mirrors into their locked position".
to anyone who's performed this upgrade and doesn't have power-folding operation after the fact, do you still manually fold your mirrors? if so do you notice them not locking into position? during the winter i go through automatic car washes so i need to be able to fold my mirrors in with no repercussions. i've got a new set of DL3 mirrors i'm interested in on ebay and would like to pull the trigger today, so thanks in advance for speedy responses.
Did you end up doing the swap? I'm not sure if my truck has the modules or not and wanting to add the turn signal feature to mine since I need a new mirror to begin with.
On 11/27/2017 at 9:16 PM, Porter_ said:
yes i did.  i used this guide here: http://www.gmfullsize.com/threads/2007-silverado-sierra-door-handle-install.93769/
hope this helps.
Not to sound rude or anything but how does swapping the outside door handle have to do with the mirrors? Also this is off this topic but does anyone happen to know if the widow switches are prone to going out on these trucks? My driver door only rolls down the driver window but the fromt and rear passenger windows roll down on their switches on their doors and my driver rear door switch doesn't roll down it's window.
    • Check the windshield washer reservoir bolt. They ALL are loose from the factory.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
