Any Problems From Running E85 ?
I recently bought an 05 Suburban with the 5.3 "Z" (Flex Fuel) engine.
Regular gas in my area is $2.65 a gallon........E85 is $2.05........for a 60 cents a gallon savings.
I've never had anything that could use E85 before and just wanted to check it out before using it.
Has anyone had any problems from running E85 ?
I hear stories of it ruining fuel pumps, eating plastic intakes, and softening rubber hoses ???
If your Burb is a FlexFuel compatible truck then you should not have any issues running it. I think most of those stories are from non flexfuel vehicles.
I say try it, BUT pay close attention to your mileage, because it will drop. Most people find that it is really a wash running E85 vs E10. The decreased mileage basically covers the decrease price.
:thumbs: I've had my truck for 14 months now. I've only run about 4 tanks of regular fuel through it. The rest has been E85. It's been over 100° here last summer and got down to -20° this winter. No starting problems, no vaporlock, nothing. :D
My regular mileage for my normal route was 13. My E85 mileage for the same route is 11. I figured up at one time that I need about 40 cents difference to "profit."
Her Flexfuel Impala probably barely justifies the difference. Last summer we put ~800miles on her car going to St. Louis. I think her mileage was 29 compared to 24. So a little more discrepancy as you get higher in the spectrum. These numbers are from memory, and should be taken with a little more than a grain of salt. :lol:
If you've never run any ethanol in a vehicle, especially in old cars, the first time can hurt. :uhoh: I mean, I've heard of guys putting E10 in a 20 year old car, and gunking up a fuel filter. The ethanol pulls a lot of shit out of things. But in an 05, you should be ok. If your normal fuel has 10% ethanol, no problems.
good luck. :P
E85 rarley makes sense economically. Your mileage will decrease about 20%-25%. Thus, to break even, E85 must be 20-25% cheaper to break even.
:thumbs:
If you have a "flex fuel" rated engine... you should have NO ill effects.
It won't hurt it at all... BUT your mileage will take a giant hit. The money you save will be made up for and more by worse mileage.
I run it in my Tahoe. As long as E85 is 50 cents cheaper I break even with the loss in milage. Right now it is at 60 cents cheaper!!! :thumbs:
I've never ran E85 in my truck and never really plan to unless it becomes substantially cheaper. I've also heard that switching back and forth between fuels can become harmful.
WHY?
To many misconceptions out there. There is nothing wrong with switching between regular and E85 (A buddy of mine has since he got his truck new in 05). I have done it with my 08 Tahoe. Just fill up and go its designed and made for it
Make sure you fill up and drive for 7 miles as the manual states so the ECM can calculate what percentage of ethenol (spelling) you're running.
I lose about 2-3 mpg in my Tahoe. It goes from about 18 to 15. This is less than a 20% drop.
Like I mentioned above, that's what my Silverado does. :P
I know this summer, there were times I was paying more than $1 / gallon less than regular gas. I know there's debate about tax breaks and such, but all businesses get tax breaks of some sorts.
:thumbs:
I use E85 as well and only notice about a 2mpg loss. This is with a Blackbear tune for 93 octane. E85 is more efficient than people make it out to be in these trucks. It also burns cleaner and acts as a fuel system cleaner, preventing carbon buildup. Do I think its an alternative fuel answer? Far from it, but it gets me where I'm going for a lot less money than premium. BTW, you guys have it good with E85 being 60 cents cheaper. Here you're lucky if its 20 cents cheaper than regular. Plus I have to go 9 miles to get it.
I kinda want to run a tank of it sometime in my Sierra, just to see what kind of performance difference it makes. I know the MPGs take a hit, but I've also heard people say the engine will make more torque with E85 than with normal gas. :thumbs:
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
