How To Grease The Slip Yoke
I have the dreaded clunk and I am going to grease my slip yoke this weekend if I can find the time. I don't have a problem removing the driveshaft but I want to make sure I'm greasing the slip yoke correctly. Does anybody have a picture of where to grease the slip yoke? Inside or outside of the yoke? I know this has been beat to death but I've searched and can't find a picture, so if anybody has a picture or a link to a thread with a picture, it would be appreciated.
I'm going to use the Valvoline Grease that I found at autozone that says it meets GM specs on their grease and it says it's forumulated for all GM vehicles. Is it ok to use this grease?
  • Replies 99
You don't need any pictures. What you do is take the bolts out of the back of the drive shaft holding it to the rear differential. Pull the shaft out of the transmission. Look inside the slip yoke, you'll see splines. Put some grease on your fingers and pack it into the splines on the shaft. Once you feel you have enough in the yoke, re-install the shaft. You'll find it's harder to slide back in because grease does not compact. Re-install the bolts and your done. :cheers:
Thanks Steven. I figured once I tear it apart it would be pretty obvious where to grease so it was probably a stupid question. I'm trying to pass the time at work 'til 5.
Specs on the grease:
-Extreme-pressure, high-temperature protection
-Lubricates at temperatures ranging from -40°F to 400°F
-NLGI #2 Grade GC-LB Lithium Complex EP Grease
-GM 1051344; NLGI GC-LB; Supercedes GM 1051195
I should be good to use this grease on the yoke?
many folks also clean and coat the outside of the yoke lightly. some theorize that the seal is hanging up a bit keeping the yoke from sliding freely on the splines. Some also use emery cloth or steel wool to clean the rust off the outside of the yoke where it fits into the trans. If I had mine apart, I would take a few extra minutes and do the outside also, just to avoid taking it apart again if it helps....
Don't forget to mark the shaft for alignment for when you put it back in. Some say it isn't required but it doesn't hurt to put it back together the same way you took it apart. :cheers:
Gentlemen,
Can't you just grease the zerk fitting?
Ken
There are no zerk fittings on the slip yoke. The only fittings I know of are on some after market u joints. And thats at the other end of the drive shaft. Kinda hard to have a zerk fitting in the transmission. would be nice though.
I'm thinking mine has a blind spline and only goes in one way.
That would be great. I wasn't sure on the newer vehicles and I have not taken mine out to know if it does or not.
+1 I'm pretty sure also. But mark it just in case. :jester:
Zerk fittings have been left off for several years now. That's why on the newer trucks there are only 2 places to grease
Rotation of the driveshaft in relationship to the output shaft of the transfer case/transmission doesn't matter. I have a two piece rear shaft. The slip yoke between the two sections is greasable, as is the slip yoke on the front driveshaft.
No, this is just general purpose grease and not thick enough for this job. It will work, but not as effectively as recommended greases. I would try either the GM tech bulletin recommended grease (=expensive), or Marine Triple Guard grease.
Where can you find that in town?
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
