Bed Rail Protectors - Who's Got Em
Does anyone recommend BR protectors for my 09 Silvy? Do they typically install with doublesided tape and look cheap or are there some that fit well and won't shift and rub the paint off..
Thanks!
I have the GM protectors. I really like them, no shifting, easy install and they match the tailgate protector.
Wow I really like those the best!. Thanks for sharing. I assume I can probably get those at GMPartsdirect right.
Thanks again!
i was looking to get these for my truck and found out when buying them online there is major shipping charges... so i have waited until i can find them in a store where someone else paid the shipping :lol:
+1 on the GM version - pattern design matches the rear tail gate design - easy to install - does not move or shift - no holes drilled ,,
I'll be adding these to my Mod's list. Again do they just attach via double-sided tape?
Thanks!
Yep, double sided pressure sensitive tape.
These are DEE-ZEE #96176 that I got from Summit Racing for $83.90 delivered. They match the spray-in or roll-on bed coatings very well.100_0101.jpg
What style/brand of cover is on this truck? Do you like it? Does it keep water out? Did you notice an increase in MPG as some claim that you get? Any holes to drill to mount? How is it holding up to weather etc?
Thanks
Joe
ttt i want to know as well.
i am looking for a bedcover.. looks nice.
lemme know!
and i have a spray-in bedliner that goes over the bedrails.
not to threadjack, but it looks like someone sprayed it and then they sprayed some other stuff on there that makes it shiny, but they only sprayed it on the tailgate and then a little bit in the bed and half of it looks shiny. anyone have any idea what i'm talkin about? maybe like a sealant for a bedliner?
Thanks
Joe
It is a TruXedo Lo Pro. I absolutely love it. Great fit and finish, life-time guarantee, and very easy to install/take off. No holes to drill.
It keeps weather out very well. With a really hard rain and the truck is just sitting outside you may get some seeping at the tailgate corners, but not much.
I have had a cover my last few trucks and I have never seen a mileage increase. I have seen a Mythbusters where they tested this theory and gave a reason. It has to do with a vortex that the bed makes that actually helps pull air over it or something like that. Doesn't matter, I will always have a bed cover and I have been very pleased with this one.
    • WOW, something we agreed on. I only bought at sticker twice. A 94 impala ss and an Acura intagra type r. Made money on the first. Still have the second.
    • I prefer new, but not without a deal. Historically I've bought severely aged new inventory, leftover model year, unpopular configuration kind of stuff that sits around on dealer lots until they just want it gone. $10k off MSRP kind of stuff on a mid-priced truck. That really, really helps knock down that first year depreciation. It also requires being somewhat flexible on colors and options. I wouldn't buy a 4 cylinder if I was looking for an 8 cylinder, but if I got blue paint instead of black, or a great deal was lacking a minor option, I'm willing to overlook those things for savings.   Used <> used. Condition and history are everything. If I'm buying used I'm looking for cream of the crop. The truck from the guy who religiously pampers it, and then decides a year later he wants newer and nicer. NOT the ex-rental vehicle, or the crew cab traded in by the family with 7 kids who like to throw food, and the oil only got changed when there was time long after the oil life monitor started alerting.
    • @Grumpy Bear the conclusion from your post about doubling engine life has me curious. Are we literally talking an expected life of 250,000 miles potentially becomes 500,000 miles with a step up in filtration for fresh oil at "the oil factory" when it's bottled? I know you said that's a single variable among many, but, that's significant if the implication extends that far into a real world use case. I would think the oil marketing folks would really eat that up and make it known.   Particles introduced during oil change is a fairly easy one to avoid, but probably not intuitive as one would think. I.e. using a clean funnel. But...what was it wiped with? Paper towel leaves behind little fibers. A solvent if not dried is not something one would want to introduce into their engine with clean oil. And, keeping the oil filler neck clean and free of buildup.. Look at some guys engine bays and they're an absolute mess. Some say that's better than the drawbacks of cleaning it. I'm not a buyer of that idea.   I've also wondered if "flooding" the top end of the engine with oil while filling is a bad idea. During normal lubrication the oil flows in a gutter back into the galleys. But if you flood the area you're potentially washing the top of the rockers, springs, and other areas which may not get much oil wash normally, and you're mixing all that into the new oil. I just don't have the patience to pour slowly. 😆
    • It was a bad pump, i had a dealer next day the pump. Gm part #86591535. Tools needed 10mm socket, pliers for hose clamps, 1/2gal of Dexcool. About 30mins to remove and install, pump located near oil filter on driver's side frame rail. I had a local mobile mechanic delete the code, he had a snap on scan tool. My scanner could not delete the code. I drove back home about 700 miles since then, and no check engine light. Hope this helps someone in the future in the same situation i was in. Thank you to all that helped me.
