On November 13, 2017 at 11:57 PM, Planefixerguy said:
Here's my '10 Silverado 5.3 just switched from 3.08 to 3.73. Took the kids to South Dakota this summer and my step-dad up north for deer opener. c48e3e6492541f9d32e0603bb581a012.jpg3382d2c704aa1c2fe271e21b66386ed4.jpga32b85e8dce24e672ea9d55cc901105b.jpgcac4c9b3efc7a692ad2bfda7e2c073c4.jpg86c3dfb2cb4051e672ae91e7afeb67f4.jpg
Sent from my SM-G935P using Tapatalk
Nice pics and good color choice. :thumbs:
Old truck with a rental trailer and new truck with new trailer. The new one still needs to be properly set up with weight distribution and stuff. That will happen next spring.
Sent from my SM-G920W8 using Tapatalk
I’ve got one of those. Need to get a pic next time towing.
Looks great! I picked up one too! a42207d8be88b3e53c942977b414d8e2.jpgb442ce474d1b59651ffe33d2bbdd3d17.jpg
Thanks! Yours too! Next step for me is to add some tow mirrors
Thanks! I got my mirrors off ebay. They are made for my truck so they are plug and play. They also push in when you're not towing. Pretty inexpensive too!
Sent from my Pixel XL using Tapatalk
That's a great looking truck! What color is that?
Thanks!! It's Sonoma Red but I pulled that pic off of Instagram so there's likely a filter on there.
    DaleB
    DaleB
  • Who's Online   3 Members, 0 Anonymous, 1,060 Guests (See full list)
