Octane Boost - 2 Stroke Engines
plowtruck
I was just curious if any of you guys add octane booster to your pump gas on 2 cycle engines and how you like it? Does it do any damage to the internal engine parts? Im thinking about upping the octane on my dirtbike and am steering in the direction of adding octane booster or mixing aviation gas with pump gas. Which is the better route for the better part on engine life? Thanks
Don't know if you already know this or not, but Octane is the INABILITY of gas to burn. You will bun 87 octane far easier than 92. Having said that...your compression ratio is a big factor in the octane you can run...for example...any engine up to about 9.5:1 can burn 87 octane fine...from there up to 10.5:1 you will need mid grade, and 10.5 to about 13:1 you have to use premium fuel of a minimum of 92 octane...
Avgas is roughly 110 octane, and is good for about a comp ratio of higher than 13. But unless you have the compression ratio to burn the fuel, or your timing properly adjusted with a Multi spark ignition, you will have much more unburnt fuel causing carbon deposits etc. The other issue is that higher octane fuels burn much hotter than regular fuel, and can play havoc on engine internals, spark plugs, gaskets and seals.
Octane booster won't hurt your motor at all. If the motor is detonating under a load, it will help. If not, it's a waste.
My yz250 will detonate a little in hot weather under a load....I can't jet out the pinging and have it run cleanly. So I use cam2 or VP race gas to stop it. I use to use avgas but it had a bit of antifreeze(not automotive) in it to keep it from freezing at altitude. It made my bike run inconsistently and I had to rejet. I use to race cross-country alot, enduros, and it would be cold in the morning and warm later; the bike ran differently as the day wore on.
If you are very concerned about engine life on a 2stroke, rejet a little fat and use good premix oil...PJ1 goldfire pro used to have octane booster in it. If you're hard on the bike you'll go thru topend's a little more quickly...I changed topends twice a year but now can get a while out of them.
Octane boosters do not work, the bottle might say "raises octane 8 points" that does not mean if you put 87 in your tank and then a bottle of octane boost it will go to 95 it means 87 octane will go to 87.8. I use to run cam2 and Bell-Ray oil in my YZ-125 years ago (like 30) but it runs hot and went through top ends pretty fast.
its not gonna hurt anything man, the difference is so small you wont notice anything...just dont hold it wide open and you wont blow it up. just like any other 2 banger. ive never used anything but 50/50 supreme/VP in my bikes...my last sled i had last year now sold...was an 03 firecat 700. 144" EXT kit, clutched, geared a little lower. 2.25" finger track on it, boondocker control box and nitrous kit. BMP head, black magic y-pipe, black magic pipes with dual stingers. set up for 800 footers... i had a EGT gauge on it cuz i also had the timing advanced 2 degrees, i had to run race fuel. but before i put that in the sled had a little switch to retard the timing for you depending on which fuel you used. i tried reg fuel a couple times (broke LOL) and when i ran supreme the EGT's never changed really at all...food for thought...by the way. that sled was F**KING FAST
Do not run octane boosters. Huge waste of money. Run only premium fuel and make sure you're jetted correctly. That is the best route for prolonged engine life. Also make sure to use a high quality two-stroke oil like Amsoil.
Read this post very carefuly. It's telling you to jet correctly, run a good pre-mix and I will add that after that you stick with the same one. Do not use Av gas for reasons stated above. You best bet is a quality fuel, quality pe-mix correct jetting and maintaining your ride. If you not racing for factory team jetting little fat is going to save your top end big time. Also never shut off the gas and let a 2 stroke run out of fuel in the carb, you just drained the oil that lubricates it!! After a long or hard ride I always let mine idle little or even on the way back to camp I pull the choke a little to load it up some and ride just little bit just cruising to even up the temps. I ran NGK gold plugs and have had top ends last seasons in my banshee. I don't own it anymore but I look at this way. A little more for a consistant plug, better fuel and pre-mix and not trashing your equipment will save you loads of cash down the road. Do it the right way and if you don't know how to jet it or figure out which way to move your carbe needle or other settings take some place that does. It will be money well spent.
I don't have access to race fuel. All we have here is 87 octane, Im in an isolated town with one gas station. Ive got a 2006 YZ250 with a eric gorr 295cc big bore kit, port and polished cylinder, milled head, stock pipe, bills pipes silencer, vforce 3 valve, twin air filter, etc, all the bolt on parts. The bike flat out rips!! I ran 50/50 av gas and 87 pump gas in it last season and it was real finicky, it seemed like I was always rejetting and changing plugs. I wasnt familiar with octane boost so I thought Id ask. I use Amsoil Dominator premix but am thinking of switching to Klotz, I have heard bad things about Amsoil. But everyone has their opinionI need to do something about the gas Im burning. I have 175lbs of compression over 130lbs stock. The bike runs good but pings every so often whenever under serious load and most of the time pings during hill climbing. I have about 20 hours of riding time (have an hour meter)since I put the big bore kit on. Im going to be tearing down the engine within the next month to inspect everything. I have a friend with a $3k SLP motor in his 800RMK that runs straight av gas and has had alot of problems so Im steering away from it. Im thinkin the best thing to do would be to rake out the cash and buy a 50 gallon drum of premium at a time.
I second the use of premium fuel over octane boost. You really do not need to run a high octane unless your equipment calls for it or you raised the compression ratio and need the increase octane to keep detonation down.
Run quality fuel, oil and proper maintenance and your should be good to go.
Eric gorr has head mods that can reshape the squish band and help reduce or eliminate detonation. That milled head probably didn't help either. With the mods you have premium may still detonate..it does in my yz250.
Also some of the race gas' can be shipped although somewhat expensive, it's cheaper than grenading the topend. You can mix the race gas with your gas so it lasts longer.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
    • Kind of off topic, wife drives a 2023 Yukon Denali with the 3.0, been a great rig so far, incredible fuel economy for a truck that big and heavy. Coming up on 50000 trouble free miles.
    • I`m gonna try some of this in my 2000 LM7 that has had the famous piston slap since 17,000 miles or so. I have used Mopar combustion chamber cleaner down the spark plug holes a few times in the past. Corrects the problem for a few months or so. Then returns. GM top engine cleaner has been used also. No good results from this.   This LM7 never used oil. Even running the piss out of it.   Course, I`m gonna use this in my 2025 L84 while it`s still clean. It`s got 13,000 miles. Used Chevron fuel system cleaner [2 bottles in tank] a tank or 2 ago.
    • Or put you in a lawn chair on the curb, with a free sign.
    • Still $4.50 85 oct.
