Painted My Bowtie!
Hey!
I decided to paint the front Chevy bowtie to match the colour of the truck! I searched on the forum and figured out what I needed to buy and went to Canadian Tire and bought the Dupli-Color products needed and painted it! Apparently Auto Zone in the States sells Dupli-Color products for those interested down south.
I bought the following:
- 3M blue painters tape
- 3M Wet or Dry paper sheets (I bought the assorted grit sheets package which had a 320 , 400 , 600 and 800 grit sheets in case of future needs)
- Dupli-Color Adhesion Promoter ( a type of primer to allow the paint to stick to the plastic)
- Dupli-Color Perfect Match Automotive spray paint ( Bought the colour I needed for truck which was Olympic White. You can get your code from glove box
- Dupli-Color Perfect Match Automotive Protective clear coat finish
I took the Chevy emblem off the front grill by prying both tabs holding the emblem to the grill. It can be tricky but a flat head screwdriver and some patience will get her out of there.
I started off by taping the emblem with the painters tape. It’s a time consuming process but take your time as you want it to look good! The new emblem makes it easy to attach tape as there’s a crease along the gold portion which allows you to stick the tape in.
After taping I took the 600 Grit sand paper and sanded down the shit out of the gold portion of the emblem and made it nice and smooth and then washed the sanded area with rubbing alcohol.
After that I took the Adhesion Promoter (primer) and sprayed three light coats leaving 10 minutes in between them.
I then applied four light coats of paint on the emblem until I got the desired thickness and colour again waiting 10 minutes between coats.
After the final coat of paint, I waited 30 minutes and applied the three coats and one heavy coat of clear coat. Again, with 10 minutes in between coats.
After the last spray of clear coat I left it to dry overnight.
When I woke up I took the painters tape off (which came off really easy) and was amazed at how great it looks! Hopefully it stands up to the elements. The paint it very smooth to the touch and does not feel like spray paint at all. I’m most likely going to get a piece of that 3M invisible bra film to protect it of rock chips!
It’s a cheap and easy mod which could always be fixed if needed!
I attached pictures of the process along with the final results!
Let me know what you think, it turned out way better than I thought it would!!
And the end results!!
Let me know what you think!
Up next is the rear bowtie!
Stef
I read on FSC that you can remove the foil on the back and then spray the back side. That way you don't get rock chips. Dunno how it would look with white though. Apparently the foil is silver and the gold color comes from the plastic. It's not clear.
I've seen that done too and was going to try it until I found out that I can't with the new front emblems....booo
looks nice, i did that with my old 84 s10 grille, did the whole thing.... not too bad once you get it figured out. I'd like mine to be silver.
Looks great!
Probably can't tell from my sig that I am a fan :dunno:
Yes I can! And to be 100% honest, your sig is the reason why I painted mine! haha!
Thanks for all the compliments guys! :omg:
    • You are winning more than battles. You're winning the war!  Nice.
    • Blazer is all put back together. Another hard-won battle. The 4.3 is not easy to work on in such an archaic and narrow chassis originally designed for an inline 4.   My baffle issue is solved. I returned to the OG junkyard but was ready for a fight. The Blazer I had picked from was stacked on another vehicle so I had no idea how the heck I was going to get myself to working height to pull the front end apart. I had seen an S10 pickup on the ground so I was hoping the part would be the same, AND, I couldn't remember if the S10 still had a front end or not. But I didn't need to worry because it turned out to be my lucky day. The yard had just taken in a '98 Blazer, sitting right up front, on the ground, with room to work around it, and the front end hadn't been hit. The baffle and all the clips were factory perfect. I also scored another good handful of odds/ends and the whole shebang only cost me $20.   Got everything back together and it fired right off, sounds good, runs good. I've got a little coolant drip from a lower water pump bolt (D'OH!!). I did the right thing and snugged it down a little bit, and of course that didn't fix it. Yet again, I will have to soak everything in coolant to drain it down to the water pump, remove the bolt, and attempt to re-seal it. Nothing is easy on this truck. Nothing. But now all the radiator plastics are correct, snug, and fully functional. No more rubbing on the cooling fan. It runs, drives (took it for a 30 mile drive last night), no Check Engine lights, EGR is working, no vacuum leaks. We're getting closer...   The replacement wiper motor arrived yesterday. The tailgate was already disassembled and waiting, so I threw that in. It works! Sort of. Two new issues on the list. While the motor is strong enough and the gears aren't stripped, the wiper is hanging up on the bottom of the rear glass. This is the old style where the lower half folds down like a truck tailgate, and the glass swings up, and they meet in the middle when closed. The glass isn't sitting flush with the tailgate, now that I look at it. No rubber bumpers that I can see for adjusting, so I'll have to look at the hinge adjustment to see if I can correct it. Also, the washer/squirter just dumps fluid underneath the truck. The lines actually run inside on the floor so I'm guessing the tailgate is soaked at the rear trim and the line is disconnected. There's also a drain there....probably for this reason.   The leaky water pump bolt was really disappointing. JUST STOP LEAKING...OMG!!   Replacing the window motor and a rear door speaker are still to do, and then everything will work. I want this to feel like a "good" vehicle worthy of dropping $600 for new tires before I do. That means no leaking first. I hurt, and I'm kind of cranky, so I'll probably take a day of rest and do the water pump again tomorrow.
    • Just saw on Jay Leno the new Scout. That’s the way it should be done.
    • EV's have their nuances too. Best to operate the current type of lithium batteries between 20-80% charge. No real need to charge until you hit around 20%. Occasionally charge to 100% when needed. Longer term storage, battery should be 50-60%. At least those are the guidelines for our iX. We've been exceptionally good to the battery in that car...easy to do when you can charge at home like we can.   EV's lack so many of the rituals and so much of the visceral feeling ICE vehicles provide, which is why I think they're hard to accept for a lot of gearheads. They're fun in different ways, though.
    • We have got a lot of rain lately, we needed it. Storms/lightning took out a floor fan. Dirt roads badly rutted from run off.   Power here is sketchy, whole house surge protector in the service panel and all electronics plugged into surge protectors. My biggest concern is my stereo, I've been an audio nut for years. $25 k in equipment. Stereo is on it's own special surge protector.
