Wheel Well Liners
Part says for 2007...will they fit 2010 ??
See post number 53 above from MS3DALE and that will answer your question and he has the part numbers you need as well.
  • Replies 152
Sam,
Here is a shot of the air bag bracket, what do you think? Thanks
Brian
Is the airline as close to the edge of the box as it appears in the pic?
http://www.gmpartsdirect.com/results.cfm?s...number=19166677
(GM)
http://www.gmpartsdirect.com/results.cfm?s...number=19166676
(Chevy)
GM-Parts Direct has them on special. For GMC and Chevy.
I Love mine they look great
From the listing
2007 new body style through current year model
Yes, they will fit 2010's
I don't understand why these don't come standard.
Has anybody found any interference by mudflaps when installing these?
i just got the bodyshop that fixed my truck to throw these in too. just waiting for them to come in. they would have cost me 80 even
What is everyone paying for these? I called the dealership today and they said 118 each, im in canada so i expect them to be more but i thought people were saying $85 for the pair. About half the paint on the top of the wheel wells is chipped off shoudl this be painted before i put wheel well liners on?
Mine (from the dealer here in Alabama) came to $107
you got robbed
I installed mine while my WeatherTech mudflaps were still on. No problem at all.
So the set from gmpartsdirect.com comes with everything you need to secure them in place? I wished I would have noticed that I did'nt have these when I was still at the dealership but i was to bust checking out all the other cool things on the inside of the truck . for any of you that ordered yours from gmpartsdirect.com how long did it take you to get them it's says it's a special order and could take 7-10 days just wondering how long it really takes to get your parts from them i'm located in Michigan thanks for any in put
Ordered a set for my 2008 GMC Denali from gmparts direct on June 8th. They were shipped June 9th and supposed to be delivered June 10th( It's about 3 hrs from gmparts direct in Winston Salem, NC to my home) They didn't come. Started a trace this morning. They still haven't found them. It looks like I will be filing a claim for lost parcel, what a pain. I was looking forward to installing them on my white vehicle. I don't know how they could lose such a large box(I assume they are boxed) that would hold two wheel well liners.
Give it time. I ordered mine from there and FedEx had them scheduled for a Tuesday delivery IIRC. Tuesday afternoon I checked the tracking number and they slipped back to the following day. They didn't arrive until dusk on the next day. Sometimes FedEx is just having problems.
waiting is not the problem. Talked with FedEx customer service advocate this morning. She said it was time for the shipper to file a claim.
Now the problem, can't call gmparts direct, no phone #. I have emailed them and gave them the case # and ask them to file a claim. Haven't gotten a response but it is Saturday.
I just can't see how FedEx could lose the package. Package was scanned when left Winston Salem, NC and no other scans show up and no transfers, straight shot to Greer, SC FexEx facility.
Has anyone else had a problem and had to get gmpartsdirect to file a claim?
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 562 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
