Changing To Synthetic Fluids
Has anyone changed to fully synthetic on their new truck...
4.3L 4spd W/T reg cab 4WD...when can I go to full synthetic?
Thanks
I have no idea what was in my truck when I got it at 42k miles. I know that it now has Mobil 1 5w-30 in it. I will be changing the rest of the fluids at some point to synthetic also.
30k Miles and I still run regular oil. :cool: Does that mean I'm banned? :cool:
This has been asked 100's of times.
Just a thought to ponder, there are cars (corvettes) that come off the assembly line with Mobil 1 synthetic so does it matter when you switch?
Usually it is recommended to wait a few thousand miles to let the motor break in before you change to a different kind of oil. After that you will be fine.
Make the switch. Worse case it starts burning oil and you have to switch back to regular oil. But more than likely it will just clean the engine up and everything will be fine and dandy.
My 1999 GMC I purchased with 32k on it. The previous owner had filled the glove box with all the service records from the dealership. All the way from 10 miles on the clock. Every time it went to the dealership, oil change to warranty work, he got a paper and it was in the glove box. When I was looking the truck over at the dealership, I manged to find that and the salesman almost crapped a frog.... He tried to take it all from me... Did not work. After seeing who owned the truck and knowing him. I kept the records and asked to take the truck home that night and think it over. By the way after 500 miles the initial break in on the engine my truck was switched over to Castrol Syntec 10w30 and has had it in it every since.
On the way home I stopped at the previous owners house. I use to sell to him, he ran the city service center (truck, tractor, police, fire department, sanitation, etc, etc.....) He explained why he traded it quite easy. I bought a new camper... Had a 5th wheel installed. They delivered the camper and the guy that dropped the camper off. Ask if that was the truck he was intending on pulling the new camper with, he laughed and said... You need a 2500 or 3500..... My truck never pulled the new camper.... He traded trucks the next day.
But back to the problem at hand. I changed a 330,000 mile Oldsmobile 98 307 over to synthetic engine oil. The engine had always had Chevron Delo 400 15w40 in it. Switch it over to Castrol Syntec. Not one problem. That engine is still tight and does not burn oil. It made the switch with no problems.. Dad had always ran Delo in that car. I don't run delo in anything except diesel tractors, so I changed it over.... It currently has over 400k on it... Let me put a hot battery in it and get some fresh gas to the empty carburetor and it will bust right off.
Jbo
136K with regualr oil, still runs like new.
Good to hear! I was beginning to think I was an odd ball. Or maybe I still am and there's just two of us. :cool:
Yep, according to these people we are odd. If feels good to be odd, though. :cool:
Why is it a corvette engine straight off the factory floor has synthetic in it? Who recommends this?
I have more belief in the lockness monster than the synthetic oil tales
30k Miles and I still run regular oil. :cool: Does that mean I'm banned? :lol:
Yes it does! We could look at it as unique though. :cool:
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
