Side Terminal Delco Battery
I just replaced my original Delco battery after 5 years. It was still good but I did not want to take any chances to get stranded if the battery fails unexpectedly. I got another Delco battery from a local Chevy dealer, same size, except the new one has slightly higher cold cranking amps (700 vs 600). The only odd issue was that when I was reattaching the battery cables, I had a feeling that the bolts did not thread as far into the terminals as on the other battery. The metal plates in the terminals are not recessed any more than on the old one, but the plastic around the terminals is a bit different. Maybe there is no issue, and the truck started right up, but I want to make sure that the battery cable terminals make a full contact with the battery terminal metal plates. Anybody ran into any similar issues with replacement batteries?
Maybe the bolt threads in the terminals of the new battery are recessed more?
This battery is one tight fit and anything even slightly bigger in size would most likely not fit in the tray.
Mine still has the stocker in it at this point. Its an 07 but I will pay attention to it when the time comes for a new one.
Did you cross thread it? If not and the cable is tight don't worry about it. Should be no problem..... A group 78 battery fills the spot completely... If you had a group 75 to start with the 78 is a couple inches longer.......
Jbo
Jbo
No, I did not cross thread anything, I always start tightening bolts by hand, then I use a small 8 mm wrench to tighten them securely. The new battery is supposedly a group 78, but it is the same size as the old one. I did loosen the negative terminal and rechecked everything - could be that the threads are just a bit more recessed on the new battery.
The price I paid was very competitive, a Walmart battery would have cost $ 77, this one cost me $ 82.
Jbo
Man, that is a great price. Around here, the only places that sell the AC Delco batteries anymore are the GM dealers, and last year I had to order a 7 yr. 'professional' battery from the Chevy dealer, and it cost $128, cash and carry. They must've made me pay by the pound. :nono:
Jbo
Correct me if I am wrong, but GMT900 Delco batteries are much more expensive for some reason. Did you buy one for a GMT800? I bought mine from a Chevy dealer and I believe it is a 6 year series 78 battery. I do not know how much more the "professional" one would be.
There is a torque spec for these terminals. If you can, torque them to this spec. If the torque holds, you are good to go. Also, the plastic might shrink a bit after a few days, check the tightness again.
Ken
Jbo
GMT900 batteries are reverse posted (like european vehicles) with top posts, and aren't nearly as common to find. Why top posts? I have no idea. Never had a side post get corroded....
Jbo
Actually the one I bought was for my '79 10th Anniversary Trans Am. I remember a 6 yr. battery with blue label being cheaper, but they said 7 yr. 'professional' series battery with gold label was the best. Hope so, because it cost a lot.
The factory ends have a crush washer type bolt (for lack of
a proper term). Once you change the factory battery to a new
one the bolts are then too long so the terminal is loose.
There have been many posts where folks that have installed
replacement batteries that try to cure this issue by over tightening the cable bolt and cracking the internal terminal lead and then the battery leaks acid from the terminal.
I just sized up a fat star washer and placed it on the face of the battery cable and attached it to the battery. This took up the added space and secured the cable end to the battery tightly.
Jbo
Man, that is a great price. Around here, the only places that sell the AC Delco batteries anymore are the GM dealers, and last year I had to order a 7 yr. 'professional' battery from the Chevy dealer, and it cost $128, cash and carry. They must've made me pay by the pound. :drool:
They went to a battery that was mainly used prior to GM trucks for;
AGCO Tractor, Audi, BMW, Chrysler (Crossfire only, due to high influence from MB), Jaguar, John Deere Tractor, Lexus, Lotus, Maserati, Mercedes-Benz, Peugeot, Porsche, Saab, Volkswagen, & Volvo.
Notice how many import vehicle companies use this battery....... It is a common battery in the import vehicle market. I do not know why many places did not have the battery to start with before GM started using it in the GMT900's.... I have had them on my shelf for at least the last 10 years.... When GM went to this battery I was stocking 3 of them on the shelf... Now I keep a measly 15 of them at all times..... Due to the popularity of the GMT-900 trucks and SUV's.
So notice how many European manufactures use this battery... IDK, GM US divisions decided to use the battery...... Seems to me the side post battery we have used since the what 70tys has served us quite well and with out trouble....
From time to time the bolt requires replacement but the battery cable lug is usually rust and corrosion free...
Jbo
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
