Krown Rustproofing
Hello All, I'm a new member here. Just got a new 2010 Silverado LT. I plan on keeping my truck for a long time and would like to get it rustproofed (I live in Ontario, Canada, so some sort of rustproofing is a must). I have been reading and searching trying to figure out what the best bet would be. From what I've read, some sort of oilspray (ie. Krown) is probably the way to go. I did not opt for the dealer rustproofing or electronic module as I heard this is not a good deal.
For the members who have used Krown on their trucks (Silverados or GMCs), where did Krown have to drill holes? Can they do it without drilling holes? Do they just drill holes in the door panels? I just have this hang up about someone drilling holes in my brand new truck! :lol: How does the Krown product affect the rubber on the truck (ie bushings, various rubber gaskets etc.)? Also, what where your thoughts on dealing with Krown.
Thanks a bunch!
Thanks a bunch!
i just had both vehicles krowned....they drill and cap the holes....my truck is black and they used black plugs....my wifes terrain is white and they used white plugs.....the caps are hardly noticable.....they will not drill if you request, but it may effect your krown warranty in that specific area (so i was told by them)
They SOAKED my truck which is what I wanted. They were very generous with the application amount.....took taillights out and all......After 9 days the truck stopped dripping.....the excess oil if easy to wipe up
i highly recommend it.....i have no idea about the bushings
What I like is Krown soaks intot he metal
where in ontario are you
You can effectively rust proof your truck with several cans of CRC corrosion inhibitor. Spray along the inner door creases on the bottom of doors, around the inner edge of the hood, remove the door panels if you do not want to drill holes and then coat the insides of the doors to the height of about 8 inches from the bottom. Let the excess rustproofing compound drip through the drain holes on the bottom of doors. That what Mercedes used to do to their cars in the 80's. (Some of the best cars they ever built).
Well, I have never seen Krown in applied. But I have seen people coat there undercarriage with just plain old motor oil from an air powered sprayer.
Personally, I don't live in a snow/freeze/salt area. But this is what I have always sprayed my vehicles with upon purchase. 3M Rust Fighter or like product. Then completely undercoat the undercarriage with rubberized undercoating.
But everything gets the door panels removed and an anti-rust compound sprayed in around my place. The inner fenders, rocker panel internals and frame. This compound also reduces noise (sound deaden).
Jbo
I've used Krown for a while.....it's a great product!
Which reminds me, I have to bring my truck in soon. ;)
For the members who have used Krown on their trucks (Silverados or GMCs), where did Krown have to drill holes? Can they do it without drilling holes? Do they just drill holes in the door panels? I just have this hang up about someone drilling holes in my brand new truck! :angel: How does the Krown product affect the rubber on the truck (ie bushings, various rubber gaskets etc.)? Also, what where your thoughts on dealing with Krown.
Thanks a bunch!
I'm in Ottawa. There are 2 Krown locations close by to where I live. Don't know which one is better.
From what I understand, Krown is petroleum based, therefore it will have an affect rubber components. I also recall a post somewhere wondering what Krown's affect on the factory coating on the chassiss would be. I don't recall seeing any info on that or an answer.
Thanks for all your replies.
Just had my car down yesterday. Great product! Been using it on my car for about the past 6 years and it works well. They don't skimp on the spray either. :angel:
There's a few more in Ottawa than just 2.
Krown - Ottawa 421 Catherine St. Ottawa,ON K1R 5T7 (613) 235-1800
Krown - Ottawa South 1768 Queensdale Ave. Ottawa - Gloucester,ON KlT 1J6 (613) 521-1800
Cotter's Auto Shop 1425 Woodroffe Ave. Ottawa - Nepean,ON K2G 1V9 (613) 224-2220
Krown Stittsville 8 Cedarow Crt. Ottawa / Kanata / Stittsville,ON K2S 1V6 613-836-1101
Krown - Orleans 2141 St. Joseph Blvd. Orleans - Ottawa,ON K1C 1E7 (613) 837-8856
I used to bring my vechicles to the Krown in Stittsville when I worked out in that end of town. Now I bring my vechicles to the one in Orleans.
Haven't been to the one on Catherine Street, but it's been there a long time.
I had mine done by RUST COP last year. They get inside all the panel swith long spraying rods. In hood, doors, tailgate, underside, engine compartment,took out tailights and sprayed. I got to watch so I seen every possible area get sprayed. They really soaked it down and it took a month to stop dripping. They said you are supposed to do it three years in a row and then that s it. I think I ll let this year pass. Guy charged my 100 cash, no reciept or warrenty. (Fine with me).
iirc Krown has a lifetime warranty on corrosion below the windshield if you follow their protection plan. Regardless as far as Im concerned it is the best rust treatment currently available. We've been soaking our cars in it for years and I cant say its ever had any negative effect on the rubber parts but I never thought about it before you mentioned it here. My 94 Caddy Fleetwood Brougham still looks mint though ;)
I switched over to Krown after my local detailing shop moved (and used Rust Check). I didn't mind them drilling holes as I was used to it with my '95 sierra. I noticed the amount of product they spray and saw the drippings it left behind after parking the truck for the day on the road. If you park in the garage lay down newspaper for a few days so it can absorb the drippings otherwise you'll be degrasing your concrete floor.
Another point if fact is for those (like myself) who are in colder climates it is better off to spray in the warmer weather as rust occurs when the temps are warmer. Therefore a Spring or early Summer spraying is recommended. If you're worried about the unsightliness of the spray wash the vehicle after a week and you'll be good as new. Rust is less prevalent in colder temps.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
    • 60psi front and 80psi rear But I am not running the factory tire brand or size! it's load range F Toyo tires
    • Open the driver's door jamb.  What do the cold tire PSI ratings on the tire placard show?   I'm not saying to run it to those numbers, but I would like to know what it says.
