Anybody Else Get This?
anybody get an odd noise when stopped in gear on their gmt-800s? like a grumbling, spinning sound?
Only does it in gear? (for sure not one of the instrument panel stepper motors or one of the actuators in the HVAC system)? Sometimes those things can sound like spinning, but it's clearly an interior noise. Does it sound like inside or outside the cab?
ive never noticed one. have you tried holding the brake and pushing the gas pedal a little to see what happens when the rpms go up?
the sound to me seems to come from lower center dash or near the bellhouseing of the trans..i asked a few friends with 800s if they have the sound, and they do ranging a from a 99 gmt-800 to a 04 gmt-800..guages and hvac do make noises but this is a constant humming while holding the brake pedal in gear
Nothing like that on mine (2006). Other than occasional gurgling from the HVAC system when the A/C is on. The only other noise that seems to come and go is subtle power steering pump whine at low RPMs, which disappears around 30 MPH. This while is only occasional.
yes its a hard noise to explain, it reminds me of a pump churning...like a very low spinning sound
Its your HVAC fan. Even when the system is off the fan still runs.
Its a throwback to the GM of old with the "flow thru ventilation"
Yes ...NO ?????????
Yes ...NO ?????????
um i don't think its the fan, as i can put my hand to the vents and not feel any sort of air movement unless i'm flying down the highway with the fan off
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
    • I'll bet your truck lost the bearings on a roller on 1 of the lifters, and now is wiping out a cam lobe.
