Favorite Feature
jro909
I like my 01 Z71 for its good lucks, the motor, pushbutton 4wd, its ability to kick ass and take names, and the hated seats!
This is now a grammar & spelling forum. :thumbs:
  • Replies 59
I would have preferred the GMC, but couldn’t find a comparable deal when I bought my 09 Silverado... That said, I love the 6 speed.
:thumbs: This has been discussed previously :lol:
check the fullsize forum (search is your friend)
But to keep this going
1. 6.2L
2. USB port for IPOD
3. Bluetooth
just thought of another..
fold down rear seats in the Avalanche along with the covered bed, so you can shag your wife in the back without her getting all embarrassed someone will see.. :thumbs:
3.73 gears
Bluetooth (I added)
Remote start (not a new feature, but the first vehicle I've had it)
And the overall look of the Sierra.
The only thing I'd change next time is get the 2500
i havent had much experience with 900s, they are very popular here but the 800 still reigns supreme... my next truck will be a 2500hd 6.0 as i can't justify the price for the duramax..i have to agree with the post about the shifter being next to the steering wheel, the only reason id want a center shifter would be for a manuel..which i might add would be sweeeet if gm built a stick that could take a beating
mines a little bit older then your guys trucks, yes i would like a new truck but i love the style of my truck. Especially with the push button 4wd, that's real handy. One day though maybe in a couple years i will buy a newer one, but till then im loving my new engine!!
Tuned 6.0L
Best brakes I've ever had on a truck.
GMC Sierra Looks.
Seats. (bad back)
If something does go bad, I can usually fix it, no special tools required.
8 regular spark plugs.
I love my truck!!!
    • I'm the original poster of this thread; I'm 85,000 miles now with no transmission issues after they did the fluid change without filter at 45,000.  I plan on a fluid change AND filter in another 5,000 miles and agree with you on staying to witness what happens if possible.  Ideally I would have done the filter at 45,000 too, but my original dealer was incompetent.  I've since moved on and get service done by another more reputable dealer, so I'm hopeful they follow the correct procedure at 90,000.
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
