Block Heater For 2003 Sliverado 5.3
I'm tring to figure out how to install and where to find a block heater for my 5.3. I'm under the impression that they went to screw in plugs. Does anyone know where I can find a screw in block heater or if Chevy dealers sell them.
Its located on the drivers side of the block,above the oil filter,Its a brass 17mm hex head plug (although it may not look brass due to age/dirt)
Your dealer can get one,or NAPA also can get them.
  • 3 weeks later...
Got mine from O'Reilly's. The socket to take the plug out cost me about as much as the heater itself. Works great though. -15 this morning, glad I had it. Easy install, I just wish they made the cords a bit longer.
so does anyone know if the know if the GM ones turn on at 0*. I was looking for something that would stay on all the time or at 32*
The GM models kick in at 0 F and below unless you remove the built in thermostat
You can buy a regular (non-thermostatically controlled) block heater replacement cord/plug at NAPA to replace the OE one and it will be on any time the extension cord is energized.
DEWFPO
