OIL Change
I was wondering do we change oil the standard 3000 miles or every 3 months.   OR is there an indicator light to tell when it is time.  I haven't had a chance to read the manual or anything.  Just thought I would get some suggestions. :lol:
what vehicle?
On the 99+ silverados they have an oil change reminder which will tell you
I still go by the 3 month 3K rule
2-3K for me.  My oil change light finally came on and I had changed the oil at least twice already (4 if you include the changes I did at 500 and 1,000 miles during break in).
Tell about the truck!!!  Whatcha got?
I intend to change every 5k with Mobil 1.  I have already changed 3 times before the first 5k though.
There is a reminder though (official recommendation).
I have a 2002 Z71 extended cab with every thing but leather.  So should I go by the standard rule of thumb or wait till the light goes on?
whatever you feel comfortable with.  Do you plan on keeping your truck a long time?  What kinda oil are you going to run?
I had myoil change light go on at 2500 miles once.  I went ahead and changed it since i knew i had reset it the previous time.
Do what you feel comfortable with as Ryan said.  If you drive yours like a citizen, don't commute in heavy traffic, don't pull 10,000lb trailers everyday, etc, etc, you can get by with waiting until the light tells you it's time to change.
When I drain my oil at 2k, it comes out awefully thin compared to what it was like when I poured it in.  I think to myself if I had left it in there for another 1,000 miles, it would've continued to break down even more.  The more it breaks down...the less it protects and cools.  Of course I drive like a homocidal maniac and tend to push things to their limits frequently, so waiting 5,000 - 7,500 miles before that light goes on is like nails across the blackboard to me.  I hear people who wait to change their oil at intervals like that and I just cringe!
Keep in mind though, I'm a preventative maintainance freak so I'd as soon replace it a few miles sooner than let it go.
Like the Fram tagline used to say...pay a little now or a lot later.
It also depends on how you drive.  3k miles of highway is much easier on a motor than 300 10 mile city trips.
I generally put 300-350 a week on mine with maybe 50 of it being stop-n-go.
So what weight (and brand?) do you guys recommend?  Mine's a '95 Z and I dunno what to use, I'm gonna chg my oil soon.
Although, the poll was about Mobil 1, you can get a idea of visosity choice from this poll:
Click here
btw-Mobil 1 calls the 10W-30, it's higher mileage formula.
Click here
Cool, thanks for the link.  Wonder why I didn't come across that in my search?  hehe, maybe I'm blind, but thanks again.   :thumb:
I recommend every 5 thousand miles on oil changes. I have always changed mine at 1K, 5K, 10K, 15K... etc. using 10w40 Valvoline. I ALWAYS change the first oil at 1000 miles regardless. The 5, 10, 15k marks make it EASY to remember when to change too. A friend of mine has one of my old trucks (96 1500 ex cab) with the original 350 in it and it is pushing 185,000 miles right now. He still puts 100 miles a day on it and it doesn't smoke and runs well. I do recommend the best quality oil and nothing but AC filters. They have always worked for me. I have since gone to Mobile1 in my new truck. I think the key here is to CHANGE THE OIL REGULARLY.
I agree with the AC filters.
GM skimps on a lot of things, but one thing GM doesn't skimp on is their lubrication systems.  If they didn't they'd be out of business from warranty costs of oil starved engines.  The filter is part of that system and if they feel it is sufficient on a Vette.  It'll work on my truck.
    needafix
    needafix
  • Who's Online   5 Members, 0 Anonymous, 644 Guests (See full list)
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
