Rust Rust And More Rust
Yes, rust happens eventually. The issue here is that it is happening after three months, not three years.
  • Replies 36
That happens too! The dealer will take care of ya.
Thats all well and good, but how many times? If were seeing rust on our 6 month old trucks how will they look in 5 years? There is no reason we should be able to keep out trucks for 10 years and not have visible rust (if cleaned and well maintained) I personally am nervous. I don't make a habit of buying a new a vehicle every 3 years so this may or may not be my Last GMC if it doesn't hold up....
Well what do you think you can buy that may not have the same issues? As I said above, go visit the other truck forums like I do from time to time and you'll see they are having the same problems, Toyota, Dodge, Ford. RUST on the chrome plated bumpers and pitting/rust spots on rims. That being said I would still be upset after having purchased a new vehicle to see this happening.
I do not know about new Nissans but my '95 Nissan hardbody pickup had perfect rust free chrome bumpers after ten years. The bumpers on my '06 Silverado are also rust free so far. I live in a highly corrosive coastal region with tons of salt spray from the ocean.
So what has changed? Quality, that's what.
Most common cause: harsh de-icer chemicals being used on the roads, as well as rail dust.
there are 3 guys at work with 2010 f150s and they are having the same problem.....i believe that the harsh liquid brine (aka GLUE) plays a major part in this.
i washed my truck today (its black granite).....my step bars are coated in a white glue filmed milk, and my side door mouldings are cloudy and caked with a film of glue.....also washed the wifes terrain and its covered in a million little "rust specs" (not rust because its also on the plastic) If it was "fall out" i would assume they would be visible on the hood and roof, but the spots are only on the vehicle from the side windows down.....the rear is a mess
wish they would just go back to plain old rock salt
  • 10 months later...
Old thread but thought I'd add to it instead of making a new one. Just washed the truck, got the salt all off. And I have a bunch of little spots on te tailgate where it seems like rust is under the paint. Like they are pin sized spots but on the tailgate??? These trucks are made way too cheap. I'd rather thicker steel and lower mpg's then rust.
Are those little spots kinda rust colored? If so, most trucks have this. I believe it's caused from rail car brake dust getting into the paint during transport from the factory. It's usually the worst on the tailgate and rocker panel area. I get new ones every year and just remove them with clay bar treatment.
I brought my truck home the other weekend (home from college) and noticed little "rust spots" all over the chrome rear bumper. I was pissed. although mine is a 2010 and i've only had it like 8 months, i knew it shouldn't be like this. Used a little bug and tar remover and it came right off. it was also all over my exhaust pipes in the back and same thing- bug and tar took it right out. I have to agree with snarkee, i think its the brine solution they put on the roads. I go to school in northeast ohio, right in the snow belt, so it gets used a lot. It sucks but it cleans up pretty easily, at least in my case
Also in NE ohio, had my white truck for 2 months i also have little brownish red speck, mostly lower on the truck. I also think its has to do with the salt or juck that gets washed up on the truck cant wait to get some fender flares!
Why can't everyone drive 4x4s so there no plows or salt trucks!
we needed more plows a few weeks back, i got over 24 in of snow, in less then 24 hours!
This is why you must Rust protect your vehicle. I Krown mine every year and I have that electro module installed.
I'm sure alot of people can say that, as can I for the krown. But those electro things are questionable. The metal is thin and cheap, but I still like my truck.
    • I will be one of those "blinded". One, I like new shiny things. Two, I've never kept any of them beyond the 3/36. Three, I don't finance anything. Four, yep, it's a waste of money....so,what? I'm doing my part of keeping automotive industry going and keeping my neighbors, most of whom are in it, employed. 😉      By the way this is the "signature... ¬
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
    • Looking for a clean, factory-style lighting upgrade for your 2022+ GMC Hummer EV? M&R Automotive's 40" Bumper Light Bar PRO features a vehicle-specific, bolt-on design with no drilling or cutting required. Choose a bright white or yellow main beam, both paired with an amber DRL backlight for a sleek OEM-inspired look. The kit includes a curved LED light bar, powder-coated brackets, and all necessary mounting hardware.    Learn more or order yours See how it installs and looks on the vehicle:
    • Looking for a clean way to add serious lighting to your 2019+ GMC Sierra 1500? Our M&R Automotive 40" SLIM Light Bar Kit was engineered to deliver maximum performance while maintaining a factory-inspired appearance.   Features: • Designed specifically for 2019+ GMC Sierra 1500 models • High-output 40" SLIM LED light bar • Clean, integrated grille-mounted design • No cutting or drilling required • Bolt-on installation using vehicle-specific brackets • OEM-style fit and finish   Whether you're hitting the trails, exploring backroads, or need additional visibility off-road, this kit provides powerful illumination without compromising the look of your truck.   For product videos, light output demonstrations, and installation content, check out our YouTube channel:   https://www.youtube.com/channel/UC3lutWP54fkXBl3iFLDJR-A Have questions about fitment or installation? We'd be happy to help.
