Advent Oem-style Navigation Installed!
check the version of your nav first. this is straight from NavMate's website:
1. Check application version
Please make sure you have the correct software version on your system: OE
a) Power on system.
b) Press NAV button.
c) Click "Press to accept".
d) Select: Menu - Setup (fifth icon at the bottom softkey bar) – Page Down icon - System (bottom of the list) – System Information.
e) Check application version.
if it says v5.2.11 then no update is needed
if it says v5.2.00, then this is the update you need:
http://www.horizonnav.com/downloads.php?index=52
if it says v.5.0.34, v.5.0.43, or v.5.0.46, then this is the update you need:
http://www.horizonnav.com/downloads.php?index=53
to get map updates, go here, but there is not an update yet for the OGM1
https://eshop.horizonnav.com/eshop/shop.php
Texas, did you try any of these? Thats pretty cool if we can do that independent of Advent.
Thanks
Ernie
  • Replies 312
I have the NAVMATE 5.2.00 version installed, so the 5.2.11 update is what I need. Problem is that the download quits before it's finished downloading every time. I've tried the download at two other locations with fast, cable internet and they all quit the download before the download is complete. It looks like Horizon Nav's ftp server is timing out for some reason. I have emailed them asking about the problem, but they have not responded. The 5.2.00 version of NAVMATE has some problems and hangs the radio more often than I'd like, so the update is important to me.
i'll have to try it later when i get home. this is just a software update, not a map update. so these are free.
But will this update the Nav app to 5.2.11?
as long as yours doesn't already have 5.2.11
It looks like there is a update on Advents site.
Not the update i was looking for. I was looking forward for other bugs to be fixed.
http://voxxsupport.com/downloads/OGM1/
have you tried out steering wheel controls with XM radio on? i'm wondering if they changed it to select presets instead of channel up/down
No it is still the same.
I want this and key issue fixed and i will be very happy.
Would someone try to download the Horizon NAVMATE update from the link below? You should get a 362 MB file that can be unzipped. It doesn't work for me and I don't think it will work for others. Horizon Navigation isn't responsive to email inquiries about the FTP site. I'd like to have this update but it doesn't appear to be available due to problems on their site.
Anxious for a reply!
I was able to down load it.. BUT the zip file was empty.. Wierd let me try a few other things.
Ok I have tried three ways from sideways... I can get the download complete but the file is empty. You will have to contact Horizon ask them to email you the download. If they do that I`ll put it up on a site so we can all get it.
Worked fine for me.
I threw them up on mediafire but had to break it up into two zips in order to not go over the 200mb limit with my free account:
http://www.mediafire.com/?1m929raz2z5pskt
http://www.mediafire.com/?nu3qezgejm66eqn
You will need winzip to put them back together. Just open the .zip file and extract. This is the upgrade from 5.2.00.
Ernie
Worked fine for me.
Ernie
Thanks! That's what I needed. I downloaded the two files from the mediafire site, unzipped them and updated the NAVMATE to 5.2.11 per their instructions. I owe you one!
Walt, just wondering how the Camera-Source back-up cam install went for you? Curious as to what you thought, as I'm looking to add one to my Christmas wish list for the wifey...lol
It's good stuff! We're going to add them to our product list and definitely will do a package for those that need both navi and camera.
For what it does at the price, there's nothing wrong with these at all, and Chris is a great guy to work with - HIGHLY recommended...
Walt
www.adcmobile.com
    • When I bought my 14 GMC I turned it off with an handheld programmer. With my 16 Odyssey I left it on solely because I didn’t have much money in the vehicle. There’s a device to turn it off that’s a little more involved. The GMC at 72 MPH the deactivation was on very little the deference was 1/2 mile per gallon. The Odyssey is on over half the time at 72 mph.
    • Anyone ever thought about switching the interior door panels from the base model to the Denali style? I’ve seen that you basically have to cut, sand, mold, paint, the window switches together to get the look right. Is that the main reason people don’t bother doing the swap? Seems like the only method that is easy I guess, without having to mess around with wiring and stuff.
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
