Maxx Cam Torsion Keys
Hi guys, I'm new here. Just joined yesterday. Just wondering if anybody has any experence with maxx cam adjustable torsion bar keys? I have a 2003 GMC 2500HD 2wd, and have new tires and wheels for it. 255/80R/17Just want to level it for the stance and tire clearance. Lots of stuff on rc and other keys, but nothing I could find on Maxx. I was just wondering about quality and any problems with that set of keys. Thanks in advance.
i used to install maxx cam keys all the time. kinda cool however it will let you over crank the tortion bars. dont set it at the highest setting. and theres a good chance you can just crank up your stock keys and get enough height out of it and not spend any money. either way plan on some new slightly longer shocks and get a front end alignment afer the fact. they are a good quality key though
I have the SuspensionMaxx CAM 3 on my 2011 Silverado CC Z71 4x4. I have had no problems or issues with it since I had it installed 6 months ago. I used the max lift of 2.5" to level my truck out. Front end is only 3/4" lower than the rear. I'm well satisfied with the product. Make sure the spacers are installed on the shocks and you won't need new shocks. Since yours is a 2wd you will not get the spacers for the front differential. Make sure you get a front end alignment after installation. In my case after installation the front end was still within factory specs when checked.
My ride quality changed somewhat (stiffer) hardly noticeable now and it's not a negative feature. Hope this helps.
You can blow your money on the aftermarket keys and make the company richer or you can just CRANK up your stock keys and get the same result. You dont need spacers or new shocks for this.
Thanks for the info guys......
I also noticed today after taking off my front wheel that the lower control arm is on the bump stop. Is this normal for this truck or are my torsion bars sagging? The truck only has 51000 miles on it.
yes its normal for the torsion bar trucks to ride on the bump-stops, its a "progressive" bump-stop if you will... if you get down adn investigate it, theres a larger squishier side thats riding on the arm, and the otherside of it is a harder compound that actually stops the suspension movement.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
