One Week To Wait. Countdown Begins
Fabtech is typically the tallest of the bunch and I can't see any reason why yours would be any different (A spacer is a spacer). 4.5" BS is way too little for these trucks. However, you should be able to trim to make room for the tires. Don't worry too much man. Go up there and drive it and see for yourself. It may only be minor rubbing that you can solve by removing the front air dam and/or doing some cutting.
  • Replies 105
Second the backspacing issue. On a GMT-800, 4.5" of backspacing is good,.. but on the GMT-900's... you need at least 5.5" :)
Sounds like you may need a different wheel.
Second the backspacing issue. On a GMT-800, 4.5" of backspacing is good,.. but on the GMT-900's... you need at least 5.5" :thumbs:
I talked to Fabtech and their recommended wheel backspace for that lift is 4.5-5.0 inches. The tech at Fabtech said that 5.71 (the other size bs in that XD wheel) would rub the upper control arm and not be useable at all.
4wheelonline also recommended the 4.5" backspace for my application.
SO, I drive the hour to see the truck. It is wayy to close to the fender for making any kind of turn. We talked about adding a body lift, but I really do not like that idea, and they didn't really either. So I guess she is going under the knife first thing in the morning. I dunno what else to do. The wheels have been mounted and they can not be returned. Live and learn??? Other than the giant rubbing issue, it looks great. The guys at the shop are solid, I talked at length with the main mechanic and he said every truck comes out different when he lifts them. He said he has trimmed chevy nbs before, but mine is close to the worst he has seen. He said if it was his truck he would trim and move on, so I guess that's what I am going to do.
yeah that is why I chose it. I didn't want to have to worry about this stupid issue. Bah. whatever. It is done now, hopefully all will be good tomorrow evening.
Have you called Fabtech to see what the problem could be then? You've done what you should have, so... it's in the installers and Fabtechs hands I guess.
I have called Fabtech. They said minor trimming is required with their 6" suspension lift and my particular wheel and tire setup. The shop considers it pretty major, the main mechanic says he has to cut metal behind the wheel. I am stuck with what I have. Hopefully it looks clean and I am satisfied......
* I talked to fabtech before I ordered all this and they said it would clear......but apparently in the real world, it does not.
i would have done at minimum 5" BS...4.5" seems too little
the xd badlands wheels only come in 4.5bs and 5.71" bs....fabtech claims that 5.71 wil NOT fit because the wheel will rub and grind against the upper control arm.
after a lot of google and bing searches, I think the 5.71 bs will fit my lift. I don't think it will touch the UCA........any opinions?
Thats basically factory BS and they will rub. As far as anyone recommending 4.5" bs, that's what I'm running and there is noooo way they would work with 35's and only a 6" lift. They are x10's but the principle is the same. I'd add the body lift...but that's just me.
Now that I think about it, I've never seen a GMT400, GMT800 or GMT900 clear 35" tires with just a 6" suspension lift. Hell, the 8" Fabtech lifts that I was putting in GMT800's like crazy for a while there, would barely clear 35's but Fabtech kept telling me, and all their customers, 37's on 4.5" back spacing wheels, for that lift. 37's would crash the fenders just like your 35's are on your truck. All that I can assume is that Fabtech's measuring equipment must be different than mine. :thumbs:
2003 GMT-800
6" Skyjacker lift
16x8 wheels with 4.5" backspacking
315/75r16 wheels
No trim, no rub
2003 GMT-800
6" Skyjacker lift
315/75r16 wheels
No trim, no rub
8" wheels and NOT a Fabtech lift. I should have specified Fabtech.
I didn't like the fabtech lift on the GMT-800's because it pushed the front wheels out even further than most other lifts due to the knuckles. The few I've seen on the GMT-900's obviously don't do that because of the new front suspension differences. I would agree that Fabtech would be tough fitting anything wider than a 8" wide wheel without modification. I thought you meant all 6" lifts :thumbs:
Also to the OP... I'd consider dropping tire size before I'd go cutting up my truck :thumbs:
I hear ya....thanks for the advice. I have been working this morning, but I am going to pick up the truck this afternoon. I told them to trim the plastic but not to cut metal. If it still rubs I will put a small body lift on when I get back from vacation. I think that is all I can do. 4.5 bs does look good. Nice black truck btw..... :thumbs:
    • Kudos? Are any of them desirable? Class leading (in any metric)?
    • Those are great questions, Bill. Our team looked into your VIN and it doesn't appear to have AFM or DFM. Please know, we take the personal and private information of our customers seriously, and we don't recommend posting your full VIN publicly. As for Auto Stop, some vehicles have a button to turn Stop/Start off for one ignition cycle. If the vehicle is equipped with the Stop/Start deactivation switch, you can push the switch to turn off Stop/Start. Stop/Start is turned off when the LED indicator on the switch is not illuminated. If you have any further questions, please visit https://s.chevy.com/support-request and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
    • She's laughing all the way to the bank.
    • There's a new PI on 2023-2026 L3B shudder.  Possible faulty front oxygen sensor.   Dealer can pull up PIP6060A and give it a read.
    • Also here's the drive cycle for a 2021 Yukon with V8.  DO NOT USE THE CRUISE CONTROL WHEN RUNNING DRIVE CYCLE!!!!!:   Warning: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage. Note: You have completed this procedure when all parameters display Complete. Short stops for traffic will not affect the procedure. Note: Do NOT use cruise control during this procedure. Ignition/Vehicle » Off — For greater than 8 h Verify the scan tool parameter: Cold Start-Up = Yes If not the specified state Ignition/Vehicle » Off — For greater than 8 h & Repeat this step If the specified state Ignition » On / Vehicle » In Service Mode — For 1 min Engine » Idling — For 2 min Drive the vehicle while maintaining the following conditions for 20 min: Part Throttle Vehicle Speed = 24 to 97 km/h (15 to 60 MPH) Safely stop the vehicle Operate the engine/vehicle within the following conditions: Accelerate the vehicle to 64 km/h (40 MPH) Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 10% and 13% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 13% and 16% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 16% and 19% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 19% and 22% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 22% and 25% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Maintain steady state throttle at 89 km/h (55 MPH) — For 10 min Safely stop the vehicle
