Are 2012 6.0 Gas Engines Flex Fuel?
I heard that rumor too about a year ago that it was upcoming.
I believe the 6.0 in HD's is flex fuel for 2012.
http://www.cars.com/go/search/detail/photo...;aff=national#5
Check the tailgate picture out.
Thanks, yes it has the FLEX FUEL badge. Nice truck, BTW. I would trade mine for it, but I cringe when I think about the difference I would have to pay($ 23k?). Man, those prices are going up. Just four years ago, the same equipment truck with Duramax in it cost this much.
The reason why I like flex fuel engine is not because I want to use E85. E85 is not even available in my area. But with 10% ethanol being added to gas and EPA pushing for 15% now, it is always good to get an engine with stainless fuel lines and other protection for corrosive ethanol fuel. This way even when gas stations illegally dump more than 10% ethanol in the fuel, you are protected.
Last I checked flex fuel really wasn't worth any savings benefit. Has that changed?
I have run E85 about 85% of the time so far in my 2010 (Nov will be 2 yrs).
  • 1 month later...
You can now go onto GMC's website and build a 2012 & yes it states under the specs for engines that the 6.0L is now flex fuel capable. Awesome!
One step closer to getting that 2500HD...
The other good thing about getting a flex fuel engine is that the injectors are "bigger" so if you want to get a blower later the fuel system is setup better for it, as the regular 6.0L non-flex fuel injectors are pretty maxxed out from the get go. That is why you see guys getting the old big block injectors when things get serious on a 6.0L setup.
L96 Engine, Vortec 6.0L Variable Valve Timing V8 SFI E85-compatible
FlexFuel capable of running on unleaded or up to 85% ethanol (360 hp
[268.4 kW] @ 5400 rpm, 380 lb-ft of torque [513.0 N-m] @ 4200 rpm))
with (E63) fleetside pickup box; (322 hp [240.1 kW] @ 4400 rpm, 380
lb-ft of torque [513.0 N-m] @ 4200 rpm) with (ZW9) pickup box delete
1 - Does not include E85 capability with (ZW9) pickup box delete.
    small navy
    small navy
  • Who's Online   4 Members, 2 Anonymous, 736 Guests (See full list)
