Refinishing OEM wheels
NARDA1
Has anyone tried refinishing their OEM wheels. The clear coat on my wheels needs to be redone and was wondering if anyone else has done this and what products they used. Do I need to strip the clear coat off or can I just scuff and recoat?
Same here. One of my wheels looks a lot worse than the olther three. From what I heard, the best way is to bead blast the wheels to remove the old clearcoat and any corrosion underneath, then buff and reclear. I am thinking also about just blasting the wheels wtih aluminum oxide to roughen the surface and painting them silver. This will eliminate any clearcoat pitting issues. Painted cast alloy wheels do not have these problems.
There are outfits which specialize in alloy wheel repair and refinishing. Some even provide mobile service. I will check into that and see how much they charge per wheel. Should not be that bad if all they needs is some blasting, buffing, and reclearcoating.
I know this won't help you guys out but I would imagine there is a wheel outfit that could do this where you are.
In Calgary here in Canada there is a wheel place called Calgary wheel. I took my wheels from my 1990 Silverado there many years ago. They put them on a lath and take a fine cut to remove all the plastic coating. Then they respray them and they look like new.
There has to be a similer process avaliable where you are!
We have that in Winnipeg as well called Winnipeg Wheel works lol
A few years ago......actually quite a few years ago, I had a Blazer, and had the factory alloy wheels polished locally. The look was very custom, but with the stock look also. The polishing really changes the shine, and the wheels take almost no care, as the polishing smooths out the aluminum so nothing sticks to them. Recoating the wheels puts you back to the same thing you had originally. If nothing else, make sure you use the stick on weight when balancing.
I have a set of CenterLine polished wheels that I let go and didn't clean last winter and they pitted real bad. I've tried everything, blasting, sanding with no luck it still shows back up when you try to polish them. Powder coating is out of the question at 75.00 to 90.00 each.
I plan on using acid then scuffing with scotchbright, and duplicolor self etching primer, silver paint and then clear coat. I will do a light sanding between coats and hope they look good.
Don't even think about it. Nothing takes the clearcoat off but sandblasting and once that's done you need a pro polisher to take it back to the original finish before you can clearcoat again. I tried this and it was a pain. Wound up buying a set of wheels off a Tahoe for mine after the ordeal. I doubted the first guy's advice [English Auto Color] so I called a few more....same answer.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
