Hey guys,
I have a 2013 with the 6.2L and have a question to see if anyone else has the same issue. It has been -40 Celsius (same in fahrenheit) for the last two nights. My truck has been plugged in both those nights. When I came to start it both times, the truck cranks no problem, starts has a rough idle for 3-5 seconds, sputters and shuts off. I start it again and it starts without any issues the second time. I have NEVER had a vehicle do this including my last silverado with the 5.3L.
Just curious is the 6.2L not as good in the cold? Is this normal? My truck only has 15,000km
Hey guys,
Actually had this happen once about a month ago. Temp was in the teens and my truck was in the garage. Fired right up the 2nd time. Hasn't happened since.
Ryan
Block heater? I don't have any issue with mine. Have you tried leaving it unplugged to see if it happens cold?
Mine doesn't have a block heater
Ryan
I haven't tried without the block heater plugged in. I doubt it will make much a difference seeing how the GM block heater barely ever turns on apparently. I left it outside tonight unplugged, Ill report back with results in the morning. Glad to hear though that someone else had the same problem.
So after the truck spending another cold night outside (-33) I started it up this morning without having it plugged in. To my surprise It started up first shot without a problem at all. Just the typical cold weather squeak all cars have haha. I read up and found that the block heater being plugged in for extended periods of time causes issues. Its recommended to only plug it in 3 hours before you intend on leaving...wtf kind of poopoo is that?
My truck starts better without it being plugged in it seems. weird. Ill plug it again tonight but I am sure the same thing will happen.
I don't know from experience but have read post from other's having this issue when using the heater. Best I can suggest is to talk to your dealerships service department as to why this does this, and hope they don't blow smoke. My best guess on it is that the temp sensor the computer is reading is either reading too hot or too cold for what the block actually is... but that is just my guess on it. Hope you figure it out.
Find a timer for the cord. Thinking even with the LLY & LBZ Diesels they recommended 2 hours & not plugged in all night.
I'm thinking with EX-F150 on this; intake air temp not jibing with coolant temp equals a confused PCM in open loop operation.
So I spoke with the dealer today. They said the same thing as was mentioned above, that they know about this issue, and there really is no fix other then getting a timer for the block heater cord and don't recommend cutting the end and installing a normal plug end. He said they have no clue why GM did something stupid like this and that I was better off leaving it unplugged then plugged in...
The hemi's not even a challenge, but on paper, the new ecoboost is. I think from a dead stop the 6.2L would pull a pretty quick lead but the ecoboost would catch up in the end. Which is faster.. well it would be close.
Haven't read though all 46 pages of this link but I would like to know if anybody makes 1 3/4" or 1 7/8" shorty set of headers for the 6.2. I read an article where 1 5/8" shorty headers produced 9hp over stock and 1 3/4" long tube 21hp. Not really a fair comparison unless both same diameter IMO.
I havent seen a set bigger than 5/8th either. No matter what size diameter you will always see greater gains with long tubes as opposed to shorties.
The area of the exhaust port on our heads is larger then the ID area of 1 5/8" tubing. I'm surprised 1 5/8" doesn't produce less power than the factory manifolds.
Would like to see an equal tube comparison of shorty vs. long tubes.
So I'm thinking about putting the autocal in my 2013 Chevrolet 1500 it still has warranty and according to the guy I been emailing He says it won't leave a footprint in the computer so if I have to have warranty work done I just return it to stock and they wouldn't know I had a tune in it is this true or not
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
