Should I Use Tow/Haul mode?
MNDave
I am leaving on a 400 mile (one way) trip tomorrow, and I will be pulling a trailer but it will be a fairly light load. Aluminum 6 x 10 trailer with two 4-wheelers and a portable ice house in the bed of the truck.
Should I use my tow/haul mode for that, or would I be better off without it on that size load?
'05 1500 5.3L
Thanks
If you find the trans is shifting real often then use it. If it drives normally then keep it off. For what it's worth, I did not use the T/H mode on my 2011 pulling a 6x12 UHaul trailer from NH to MI.
I pull a 5x10 utility trailer with my Escalade loaded with a Kawasaki Mule UTV that weighs about 1,000 pounds. Generally, We are going camping so the back of the vehicle is generally loaded with "stuff". I only had to use Tow Haul mode one time...I had the Mule bed loaded with firewood, and really had it overloaded. I only needed tow haul mode when going up and down hills when the tranny kept shifting its heart out....
Otherwise, I don't even think about it. Realize though, the Escalade has a 6.0L engine vs your 5.3, so there is a small difference in HP and torque...it has a tow rating of 8,000 pounds, and I have never got close to that....
Why would you not use it? You may see a slight decrease in fuel mileage, but I'd gladly take that versus shortening the life of an expensive transmission. Plus it offers better engine braking if you're going to be in hills.
If the trans isn't always shifting or lugging in gear, you aren't shortening the life of anything. I figure at most my setup was 3,500 lbs and all T/H did was keep it in a stupidly low gear when it was not needed. This was with the 6-speed though. the 4L60 may not be as well-mannered. I also downshifted as I felt needed for hills. It was never in any danger. The only time my trans temp was over 200 was when I was stuck in traffic in Cleveland for an hour and then it only hit 205, nothing to worry about. Otherwise, 150-170 degrees for the most part.
T/H mode also increases the pump pressure and allows for quicker/firmer gear changes. This means less slippage of the clutches when shifting while towing. More slippage also means more heat. Heat is the mortal enemy of an automatic trans. Do whatever you want, it's your trans but it's not that hard to push the button.
Excess heat isn't a problem if the trans isn't shifting. Once I got out of the hills in MA and eastern NY the truck pulled 6th 90% of the time. The 6-speed shifts no firmer in T/H in most situations, it doesn't have the night and day difference the 4 speeds have with it. If you actually read what I wrote you'd see I was monitoring trans temp the enitire time to make sure things were okay.
Yes, yes and Yes. Your truck will appreciate it greatly. Think of the tow haul button as a tool provided to help you do your job. :driving:
I really don't understand why someone wouldn't use this item? Is it because it may use a bit of extra gas? A/C uses more fuel to run also. Do you leave it turned off all the time also? It's not "required". I assure you, this system was designed by someone with a lot more automotive engineering experience than 99% of us here. But as I've said before, it's your truck, your transmission and your $$$ that's going to go into fixing the transmission prematurely by not using it as designed.
Tow/haul is for hills to keep the truck up and downshifting so much, on flat land its just a waste of gas
I've explained myself 2 or 3 times now. Gas use is not a concern whatsoever. I chose not to use it because all it did was keep the trans in 4th or 5th when it ran steadily, WITH NO SHIFTING WHATSOEVER in 6th for the bulk of my trip. There is no reason to have the engine running at 3500 RPM on flat land, you gain nothing other than drowning out the radio. If the truck started not wanting to stay in 6th, I'd switch to M5 or M4 depending on what the situation was. Other than the hour being stuck in traffic, my trans ran at a max of 170 degrees (F). That is normal operating temp and nothing to be concerned about.
It isn't about engineering experience, it's about common sense. I know what conditions pose a risk to the truck and they were not present during my trip. I guarentee you that my transmission will not fail prematurely because I did not use T/H mode. This truck is spec'd to pull 9,600 lbs. I had about a third of that behind me, at most. There was no risk. All T/H would do is make the drive louder and make me stop for gas sooner which wasn't really a concern as I was not paying the fuel bill anyhow.
To the OP-
Use T/H mode if you're at all worried. I chose not to because I know what to look for hazard-wise when towing.
How do you figure it's a waste of gas? Even in T/H mode, on flat land my truck will shift into OD when pulling a lighter load. When I'm pulling a heavier load, I keep it in 3rd, in T/H mode. T/H will not prevent the transmission from shifting into a higher gear if it determines that gear is appropriate.
A few times while towing my travel trailer (5500 lbs in T/H) on flat ground I tried putting the trans in OD. On level ground the truck stayed in OD but my fuel mileage did not increase at all and the trans temps went up. Put it back into 3rd and the mileage remained the same and trans temps went back down.
Your trailer is more than 2000 lbs heavier than what I towed. At 5500 lbs I'd probably run T/H too depending on how the truck behaived. My point is just that T/H as a blanket recommendation with any trailer is a bit silly.
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
