I did some searching, but could not find what I need. I have an 04 GMC Yukon XL SLT (3/4 ton, 4x4, quadrasteer) and the DRL's just do not work anymore. I see lots of folks wanting to disable them, but I'd like to get mine working again.
I pulled the socket on one side. The socket was a little blackened around the bulb, but still in good shape. Both bulb elements tested good with my Fluke meter (although it appears the socket can really only power one of the elements, so not sure why there's a 2 element bulb in there). I get no power to the socket terminals. Engine running, in drive, sunny day with the lights on or off. Nada. They do flash when I lock/unlock the truck, though. I changed the fuse and the relay for the DRL's, but it made no difference.
If they didn't flash with the lock/unlock, I'd suspect a wire. But it's got me kind of mystified at this point.
Any hints on what to look for would be appreciated. Is there an online wiring diagram for these trucks?
Edited by jeb
The DRLs have worked before while you've owned the vehicle? If you're not the original 4114 is the bulb #
Make sure your emergency brake isn't applied even just a notch or two. More later...
Thanks for the reply. I did make sure the parking brake was not on.
I've owned the truck since new, 86k on the clock. Always babyed it. And yes, the DRL's for sure used to work. I'm not sure how long they've been out.
Usually the parking lights flash on lock/unlock not the DRL, unless they changed it on your year-2004. I put the 4157NALL in mine. Looks better with amber. Don't know why they use the 2 filament bulbs, maybe need the heavy filament for the brighter light. Do your auto headlights still work? I was thinking maybe the light sensor on the dash might be screwing up. I had to bypass mine, it was keeping the headlights on all the time.
Also note that certain year DRLs only turn on when truck is in gear.
Can't remember when my 04s came on................
Tesnoboy picked up on something. You said they flash when lock/unlocking. As he stated only the turn signals flash. The DRL will illuminate when it's dark, but they won't flash. Are you checking the correct bulbs? Lamps are closet to the radiator grille opening.
DRLs only work in gear. Put the truck in drive and I think you can set the parking brake and still have them work. I did this with the key on/engine off to check mine on my 2003. I think. Traded it in 2008 so it's been a while. :lol:
He's already done that Mike. :)
Oops! Well they shouldn't flash when you lock/unlock I'm pretty sure. But I'm gonna bow out since I can't seem to read tonight. :lol:
Sorry for the late reply, and thanks for the input. Dirt bike races have been consuming me of late, so not getting online as much.
Yes, the auto headlight sensor does work as normal. Tested several times now as I'd read that was a possible cause.
The signal lights also blink when I unlock/lock the truck. The DRL lamps come on with them, and stay lit for 10 or so seconds after the signal lights go out. Backup lights stay on solid like the DRL's for the same time duration.
This happens during daylight? The DRLs remain lit as you descrobe? Are your headlights on all the time during daylight? Sounds like the ambient light sensor is bad, tricking your system to think it's dark
Edited by txab
The DRL's and backup lights staying lit for 10 seconds after unlocking the truck happens in dark or light. I'm pretty sure they have always worked that way. The headlights are for sure not lit during daylight. I have no lights on at all right now in daylight. The headlights do come on automatically when it gets dusk/dark. The ambient light sensor seems to be funtioning as it should.
During daylight conditions the DRLs shouldn't illuminate at all when unlocking or locking in my experience. When my ambient light sensor failed, my DRLs illuminated during the day as you describe, but also my headlamps were on all the time as well
I just tested it. You are right that the DRL's do not come on when locking/unlocking in direct sunlight, but do in dark conditions.
So there seems to be no question that the ambient light sensor is good.
Fuse is good. Relay is good. Bulb and wiring are obviously good or they would not come on at all.
Anyone know of wiring diagrams online for these trucks?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
