Hey chevy.. If i got an lbz or lmm, Cant i upgrade the oem turbo and make power keeping it a single turbo, with a good tune?
Whats the real difference between 2 smaller turbos or 1 big one...
replaced an oxygen sensor and burn my hand
No girls where you're from or what?? Lolololol
hahaha well sadly enough i have a girlfriend so i dont have to burn my own hand
I'm no professional on this subject I'm sure their is people who know a lot more. But I have read a lot, researched alot. If you just "upgrade" stock turbo with a billet wheel you can get about 530rwhp with a lift pump, exhaust, CAI and a good tune. But anything after that your pushing its limits running it out of its map. Their is MANY other mods you that have to take place before you begin to worry about other turbos. The stock turbo has enough potential to destroy your transmission. Tranny, lift pump, sump, exhaust, gauges and a few other supported mods are MUCH needed before you up turbo size.
The difference between a big single and twins is twins will have better driving characteristics, smoother power, lower EGT's, lower drive pressure(important) and turbo(s) will last longer. A big single can make huge power, but the boost hits hard, towing isn't as good, higher EGT's and your pushing one turbo to make the boost that two could do with half the effort...catch my drift? It's just common sense, two air pumps is better than one to achieve the same boost pressure...
I have read (don't know if it holds any authenticity) that a twinned engine running the same HP as a big single turbo engine will last longer. It is safer power.
The ONLY draw back I see do doing twins it's ALOT of work, more rotating parts. some guys have a hard time with boost leaks. I know first hand installing one. It's a PITA. And they cost quite a bit more...
IMO their is pros and cons to both. In the end, it's All relative to how much $$$$ your wife will let you spend lol
Thanks..that all makes sense..Probably why ford went with two turbos on that 6.4 they made after the disaster they had with the 6.0!
Im going to definitly do the suncoast ally for the big block truck, And the d-max truck if i get one.. The guy at duraburb said the allison holds up pretty good up to 450 hp and like 8 or 900 ft lbs..Anything moe then that and it will go into limp after 3-4 times hammering into it..
Do you have the stock wheels from that truck? Im looking for an oem set of 17,s
Ya once you limp it your screwed, it will get easier and easier to limp. An ya they hold up to about 450, depending on your foot.
And I'm laughin at the 6.4, that was a disaster of an engine as well. Probly why it lasted as long as it did, the only good one to get from ford was 7.3...
My dad owns the new 6.7, so far it's been good truck!
Dropped the truck off at the dealer to get the new water pump installed, 2nd one in a year. Also asked them to check out the emissions stuff, maybe see why my exhaust smells like ammonia so bad. Runs great, no CEL or anything just stinky exhaust.
Picked her up this afternoon, new water pump looks good. The tech checked out the emission stuff and said everything is working as it should, no issues so it must be the quality as gas around here.
Couldn't wait to get it home and put the tune back in. Stock= boooooooooo, lol
I got bored at a stop light.
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Yea until I ran the part number. I digit off. Its exactly what I'm looking for
Heading out for a nearly 4 hour drive to osseo Michigan to work on my prerunner bar then another 2 hours to Rochester hills to play with some dirty duramaxes good weekend to get away.
Drooling over a TVS1900 on pt for $4000.....
I'd go for it Frogfish, a little birdie told me that they are a freakin' blast. This is a video link, my first. Hope I did it right...
update- link won't work, I'm too old and stupid to link a video from photobucket.com. I've never posted to youtube, but I'd probably screw that up as well...
Edited by SILVERADOSC540
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
