Is Tulsa that bad?
No not really definitely not worse than St. Louis. Just some shady people out in the hotel parking lot.
Sent from my DROID RAZR using Tapatalk 2
You live a world away from Detroit Sarah. Hell, even I would not be worried about a Detroit-based crime where I am. :lol:
im spending this weekend there, i told you this mike YOU NEVER LISTEN TO ME!!!
lmao :lol:
Edited by SarahsGMC
lmao :lol:
No, you said you were coming to my "area" or something similar. Jackson is like 80+ miles away from Detroit- it'd be like calling Toledo my "area". :lol: Did your parents never let you see a map growing up :P
I'm driving to school and I'm pulling 17.8 MPG with the 6.0
Sent from my DROID RAZR using Xparent Red Tapatalk 2
On my drive to school my DIC went black as well as the shift lever indicator. My dimmer is on it's way out
lol..........That number is far to high, means you are not pressing the pedal hard enough. :driving:
It dropped to 16.9. Remember I am still running 3.42 gear. I was doing 55 MPH getting 17.9. When I stepped up to 75-80 it went down
Plans changed to lansing now im even closer, cleaned snow off it again
Edited by SarahsGMC
Left Jackson last night around 6:00, drove through the night and got to NH about 30 mins ago. Poor truck is filthy now.
Prepped for the blizzard warning. Tonight should be fun on the dock. 12 inches of snow blowing across polished concrete on a 7 thousand pound forklift with slicks on it and spears sticking out on the front. Let the games begin!
I went and took a few pics of the truck as it was starting to get dark.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
