Doubt anyone on the forum has seen one of these before.8y9u2yhy.jpg:P
Sent from my DROID RAZR using Tapatalk 2
I've seen it- that was in a section of the owners manual I skipped. :lol:
:lol:
Hopefully I can get an upgrade after I get my tax return.
Drove to the casino. Pulled 18.6 MPG. 145 miles round trip. Like 10 city and 30 mountain. On the highway set the cruise to 55. In the mountains it was constant accel then brake for a hard corner and repeat. I don't know how I feel knowing my truck can do this on the highway and only get 11-12 in town
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
I was given like $35 for driving. $20 cash and my friend and his dad bought my buffet. They know my engine is bigger than his 03 Z71. I used $28.78 in gas there and back so I came out on top. None of us expected the 18.6 MPG
Edited by chawkins6789
Was out at 4:30am and planned on letting the truck warm up before heading into work in the snow and ice........DEAD BATTERY!!!!!
The battery in my 2010 took a crap, "start vehicle battery low"......Tried to start, no go.....Battery showing 7Volts. What a piece of crap.
My 2008 fired right up, still on the factory battery! Going to have to see if they are different when I get home this afternoon.
Some are better than others. The orginal battery in my truck lasted 4.5 years. The replacement I put in before I moved to florida lasted 1.5, red top lasted 3 yrs, 3 days(pissed me off because it went bad 3 days after the warranty expired), my yellow top has been in for 2 months so far
Going to grab a Deka (9A48) from the maintenance garage after work.....Never had one before but they seem to work pretty good in our work vehicles with all the electrical equipment in the vehicles.
Nailed a deer on I135 somewhere between salina and wichita ks. Was goin about 80 and it impacted my truck just in front of the drivers side rear tire. Cracked my fender flare and dented the body under the fuel door. No major damage though
Sent from my SCH-I535 using Tapatalk 2
I've had a few close calls on that piece of highway. Glad it didn't do much damage.
Drove to the bike show!
Drove it for the first time in 2 weeks to work due to impending snow on Friday. Glad I did because it started an hour before I left...gotta love living in the 'south' where people don't know what snow is or how to drive in it. It took me 3 hours to drive 25 miles all on the highway. Found out the Transforce HT tires are crap in snow too.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
