Sitting at the shop waiting to get my pipes dumped. Gonna keep true dual straights just dumped over the rear axle. Hopefully this guy makes em look good....
Sent from my SGH-I927 using Tapatalk 2
Edited by zach1990
I finally get my 300 amp alternator back
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Finally got around to painting my frame today. Made the body lift look much better IMO. Also had some paint and clear left so I pulled my lower valance and sprayed it to.
Installed chrome door handles one of the bolts for the passenger side handle is stuck couldn't get it to tighten all the way thus the handle is loose on one side. :angry:
Sent from my DROID RAZR using Tapatalk 2
My rear brake drums were causing the brake pedal to pulsate and the rear of the truck to shake. After a trip to Napa and about 30 minutes of DIY, I now have new rear drums. I took it for a test drive and the issues are gone.
No issues getting the old ones off? May have to do mine soon.
I had some drums stick awhile back I had to hit them really hard with a ball peen hammer on each side more than a couple times. It surprised me because usually its one or two light hits.
Sent from my Nokia 5190 using Tapatalk 2
Edited by tanked_darren
Look more more finished off Zach.
It's more like what I did yesterday but... :shakehead:...a light pole jumped out and bit my truck.
Right at the trailing edge of the front door and the leading edge of the rear door on the passenger side. I haven't got a pic of it yet. It doesn't look too horrifying but boy do I feel dumb. I was pulling into a fast food place with the wife and their parking lot was full on one side so I pulled around to the other and it was all end to end parking so I attempted to parallel park in one of the spots. I miss judged how close I was getting to the concrete base of the pole, plus paying too much attention to my rear bumper location...BAM, screech, scrape, and me saying a few choice phrases. Parallel parking should be banned... :M16: Not going to bother getting it professionally fixed, just sand it down and it get it covered so it doesn't rust. I guess I just gave my truck some character.
Morale of this story: Don't take your wife to lunch! :cheers:
Not to rub it in but somehow I parallel park like a pro not sure why but I always get it perfect. My driving instructor made me try it my first time between two 50s style hot rods boy was I mad at him but I did great.. Maybe I should be a valet..
Sent from your truck via Tapatalk
:P
Just kidding, I usually can do pretty decent however, I was so worried about hitting something off the back bumper I didn't even notice the base of the light pole sticking out.
Drove back from the airport in the snow. Took forever. I also need new tires, these ones suck even though there is some meat left on them.
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
