these types of comments arent needed.
What type of comment was presented?
Doesn't sound like you did anything wrong. For some reason, certain newer mods. get weird like that sometimes, even though the posts are normal. Similar comments were made about a post or two I made a whike back that there was no issue with. The mod who commented to you didn't see any problems either.
Sent from my iPhone4S
using Tapatalk
It wasn't towards me.lol, rather than.to.another person. Just wondering what he said.was, if indeed was, incorrect in judgement.
Jon's comment was made towards me because I am a member on silveradoss.com as well. I saw no problem with it. Maybe a bit of sarcasm or a bit condescending, but I take no offense to it because my tickets were from well just going 15 mph over the limit on long drives. Justin and I got into it over a thread I had about a ticket a year ago, but water under the bridge. I see where I was out of line and I haven't had a ticket since
Here is the engine cover on the car
Sorry Sarah,it was not my intention to offend anyone. Chris, I was not taking a shot at you, I'll PM you.
Edited by SILVERADOSC540
When's the supercharger going on that beast Ryan?
No plans for one currently
Translation: the wife said NO :lol:
Honestly I havent even really thought about one. If I wanted to go the supercharger route I would have went with the ZL1 or I will go with the ZL1.
She would say no but I havent asked
They say that it's easier to ask for forgiveness than it is to ask for permission...
That it is.
Just dont order large items (see photo), she wasnt happy about this one :lol:
She did like the sound after I installed it
I drove it to breakfast. After cleaning the MAF and TB it runs a hell of a lot better
To Ann Arbor for work then tonight to UPS to return a package to Amazon. Then some old man pulled out in front of me. Nearly hit him.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
