Washed the truck and changed oil tonight
Ryan
if i raced you with my 4.8 i would kill your truck, i would be about 3 car lengths ahead the whole time, idk if ill get traction off the line though, i have way to much power
Just keep it out of 4WD at the launch, at least give me a chance...
Just got it installed and did the crank relearn. I don't know how to describe it. It's a lot better. The words my brother used were "It's like sex and cocaine", I feel a lot more power and it makes me smile
Strange, back in the eighties I could never really make those two things work very well together. You'll be happy with all that power for a little while, that's when the cocaine and sex deal turns into a crack addiction and you just want more.
I put the 6.0 in and I want more.
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Driving the truck after I reflashed stock for the 87 incident and.uggg......can't get through the tank fast enough.
Returned bottles.
Then I attempted to get my knee bolster off. I gave up because I'm unsure of where the clips are situated. I will experiment with a yard truck at work hahahaha
Sent from my Nokia 5190 using Tapatalk 2
Wait, why did you need a crank relearn?? The shop that did the install never did that for you??
He has no clue :lol:
Ryan
Nope and he is missing out on ALOT! I remember test driving mine, and thinking omg this is amazing. Even the sound of the engine at WOT is amazing. Sounds like a Camaro.
Lmao! Funniest thing I think I have ever read on here!
Ma'am your husband told me to do it so I did.
Justin said that could be the cause of my p0300.
And Jenna remember I said I don't like dealing with that shop. I don't know what was done aside from them giving me an LQ9 and flashing my computer so it will run
Edited by chawkins6789
Ryan
Some people can't afford a new truck. I can afford to add power over time
And who would that be?
I got you both beat. I make $3600 a month tax free and all I do is go to school one day a week. I sleep in til noon every day. The only thing I have to do is pick my brother up from school, and go to school Tuesday nights
oh-no-you-didnt.jpg Edited by SnakeEyes 325is
Ryan
There are used ones out there
Ryan
I can turn off traction control. Truck does burnouts just fine like that. :lol:
Yeah and then there are used 800's for much less, with no TC nannies, which I'm sure Chris appreciates. :lol:
Which does make them run better IMO. I think my 05 5.3 ran better than my 09 did.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
