Yea pretty much I didnt watch because we were at the dealership and he took it into one of the bays.
The first place I was going to go was going to charge $75. The guy charged $20, I ended up give him $40. Definitely well worth it :)
Pulled a trailer load of top soil home and now the dash in the Pigg is lit up like a christmas tree!?!?!?!?!? :jester:
I ran to Home Depot for BBQ supplies and then to the grocerystore
And just drove my mom to the ER. Truck didn't see OD
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Nice. I bet he enjoyed the tip. :)
P0300 returned again. Truck runs better though. Stuck in the hospital with my mother. I'm not happy the doctor won't move her bed to the kitchen
Got my exhaust tip today. Hoping to get it put in Wednesday. This thing is HUGE! Thanks to Jerry for finding this beast!
I drove to the hospital to visit my mom.
Bad allergic reaction to something. Not sure what.
Hope everything turns out good for her
Sorry to hear that. Hopefully they figure it out, I'd want to know what it was if it were me.
She has an allergy to seafood. She ate oatmeal prepared at home and it started before lunch yesterday. Then she had a salad for lunch from a place that doesn't serve seafood. I brought her in and they admitted her last night but she still isnt in a room. She's sitting in overflow. She just got a room but hasn't been moved to it yet
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
