Put these on today.
78906A9E-2579-44B4-9E78-392128FF5AD7-695
Did wheel bearings and brakes on both sides in about 2 hours.
BD39B8A1-F831-451E-B107-3F5651EBE4D5-695
Stopping power is great from these bad boys and they aren't even broken in!!!
Ive got the green pads myself and it stops on a dime. Good Choice!!
Edited by BruceDeuce
Put the Extang Black Max on the truck yesterday, Got it used for $75.00 Craigslist. Everything was there and the cover is perfect.
Earlier post I wasn't targeting you just to let you know and for the black.Max, I have one also and it works and looks awesome! If it seems brownish or faded, buy the stuff they make to condition it back to normal.
Just got off the dunes too windy but it was pretty smooth
And looks like blackout is going to get his wish because I've absolutely had it with these exhaust hangers breaking... The exhaust shop that did them did an awful job welding... So im trying to decide what route to go.
Different exhaust shop or dump. Possibly turn both pipes out to the right
Just got off the dunes too windy but it was pretty smooth And looks like blackout is going to get his wish because I've absolutely had it with these exhaust hangers breaking... The exhaust shop that did them did an awful job welding... So im trying to decide what route to go.
Dumped.
What do u mean by dumped just straight pipes no muffler
You will hate that the next time you take a long drive. In my 2003 I had a super 40 ending under the bed and even that sucked.
I guess I could sawzall them off they won't be turned down they'd be straight out for a few inches I have a flow master 10 on there
I had turndowns to dump my 40. And Mike is right, long drives were miserable
    Frank V
    Frank V
  • Who's Online   7 Members, 0 Anonymous, 1,225 Guests (See full list)
