Put these on today.
78906A9E-2579-44B4-9E78-392128FF5AD7-695
Did wheel bearings and brakes on both sides in about 2 hours.
BD39B8A1-F831-451E-B107-3F5651EBE4D5-695
Stopping power is great from these bad boys and they aren't even broken in!!!
Ive got the green pads myself and it stops on a dime. Good Choice!!
Edited by BruceDeuce
Put the Extang Black Max on the truck yesterday, Got it used for $75.00 Craigslist. Everything was there and the cover is perfect.
Earlier post I wasn't targeting you just to let you know and for the black.Max, I have one also and it works and looks awesome! If it seems brownish or faded, buy the stuff they make to condition it back to normal.
Just got off the dunes too windy but it was pretty smooth
And looks like blackout is going to get his wish because I've absolutely had it with these exhaust hangers breaking... The exhaust shop that did them did an awful job welding... So im trying to decide what route to go.
Different exhaust shop or dump. Possibly turn both pipes out to the right
Just got off the dunes too windy but it was pretty smooth And looks like blackout is going to get his wish because I've absolutely had it with these exhaust hangers breaking... The exhaust shop that did them did an awful job welding... So im trying to decide what route to go.
Dumped.
What do u mean by dumped just straight pipes no muffler
You will hate that the next time you take a long drive. In my 2003 I had a super 40 ending under the bed and even that sucked.
I guess I could sawzall them off they won't be turned down they'd be straight out for a few inches I have a flow master 10 on there
I had turndowns to dump my 40. And Mike is right, long drives were miserable
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
    • 87 down as low as $5.14 here... winning!
