Took my truck in for an alignment and got a call saying it was gonna cost $658 dollars for an alignment, 1 tie rod end, 1 upper ball joint, and an idler arm. Promptly told them id come get the truck and replace the parts myself. Then had some fun on the way to work when I noticed they had taken the passenger side wheel off and didn't tighten it back down. Lost 2 lug nuts and 2 more had almost completely backed off. I'm a bit on the pissed side. Sorry rant over now
Sent from my SGH-I927 using Tapatalk 2
Think I'm going to be getting me some 35 inch mud grapps and run them on my stock 16s with a 3 inch body lift. Then ill get a black bear tune... Goodbye paycheck !
Sent from my smartass iPhone using Tapatalk
I gassed up the truck and started packing it up. Should be starting my drive in 5 hours
Drove up to St Ignace for the car show weekend.
That show is not the same anymore, should have been there 20 years ago. Twice the cars, twice the people, 4 times the party, 1/4 of the police. People used to camp anywhere they could find grass in town now they do not allow it
Twenty years ago I was eight years old and none of that would've mattered. :lol:
Hit some mud. The nerf bars do help keep the splash down
Ryan
Edited by RyanbabZ71
The silver blends the spray on the side of the truck. Dirtiest this thing has been since I got it.
Go through a mudhole in the field with 25000 pounds of grain in the cart and you'll see dirty. :lol: The once shiny new tractor is now a mess.
I just drove to Vegas
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Drove to outside Provo Utah. Another 2 hours left
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
