I want a 70
Ryan
70 is my favorite year too but I'd want a 71 bumper/tail lamps.
I've had a few 68's about 7 and only 1 69. All the 68's were big block cars some auto's some 4 speeds. The 69 was a small block that I got for a song and kept about 20 minutes before I sold it, Back in the day it paid to have cash when some one needed it, I got some good deals over the years. Only problem is I would not have any room if I had kept them all!!!! My dream is to build one more street car from a 68 with a 427 big block, 5 speed Lenco, with a set of 4:56 or 4:88 rear gears just to give the locals some crap!!!
And yes Ryan my oldest son did live there until today!! He still owns his house there but he is not back home in AR not at my home but he lives here not. :jester:
Drove from Utah to Vegas. Its 120 degrees here
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Hope your AC works good. :D
Oh it does. So does the trans cooler
Cruising the Vegas strip
Edited by chawkins6789
Well I did my first Data log for my Autocal! Cant wait to get this thing tuned~!!!
Glad ya like it Chris. Vegas holds absolutely no appeal to me. I'd like to see other parts of Nevada for sure but the big city certainly isn't it.
The only time I really want to go to vegas is for SEMA
Washed and waxed the truck today. Also sealed the roof (havent washed the roof in forever).
Pics, only garage shots today because it decided to rain this afternoon/evening :(
Woke up in Des Moines Iowa, going to sleep in Blue Ridge Georgia. Long drive. I B tired.
sounds like a movie plot for another hangover movie
Bought a unlocked OEM radio with CD and aux on eBay . Hopefully it gets here by Friday or Saturday.
Sent from my DROID RAZR using Tapatalk 2
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
