I thought all gen 4's had either 87 or 90 mm throttle bodies.
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
4.8 and 5.3 have the 78mm
Sent from a jelly bean.
I wouldn't worry to much about your warranty, you can always go back to stock setting just before you take it in for service if it makes you feel better, if you use the Auto-Cal.
About the LS7 TB, the only thing I noticed with it was quicker throttle response and smoother idle.
I did the LS7 tb first then the air aid jr and the long tube hdrs and the tune last. I think the tune makes all the bolt ons work well together as a whole package.
what headers did u go with???
People love taking photos of camaros. Driving home from work on Friday I had a lady taking a photo of my car at a stop light with her ipad. Looked pretty funny, probably wouldnt have noticed if she used a cell phone
I had a V6 rental Camaro sometime in mid-2010 and they were still new enough that it turned heads everywhere. Didn't help that it was bright yellow. :lol: I was actually here in Michigan that week (before I lived here) and met some friends for dinner at a BWW in Brighton. I pulled in and there was some kids birthday party in the outside dining area because as soon as I parked there where 5 or 6 sets of little eyes poking above the fence. Then my buddy showed up in his 69 Chevelle that you can hear from the moon and I was no longer cool. :lol:
Took the twins for their one year shots. 4 each equals
Two angry lil guys
Edited by SnakeEyes 325is
Serviced my A/C qnd witnessed a stand off at a funeral home. I was stuck at auto zone because the sheriffs had the road blocked
I washed it for the fist time since June.
Sent from my DROID RAZR using Tapatalk 2
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
