Small fire got 3 engines 2 ladders, and 2 battalion chiefs
Building shelving for storage at the new house
My mom finally bought a chevy. 2013 malibu with 37 miles. It seems like a nice car so far.
Sent from my LG-D800 using Tapatalk
I need more wood for more shelving in the 40' sea train. So Home Depot tomorrow when I wake up for 7- 2"x6"x8' boards, 2- 2"x4"x10' boards, and 1 sheet of 15/32 plywood.
Stopped in front of a friends house to say hi...
I did that in the Abertson's parking lot last night while my friend was collecting carts at 11:45 PM
Rawwwwr. Pinstripe gone.
C6111D68-09ED-4322-8059-EDDCBA5DB529_zps
Truck looks good Danny! You should get rid of those trim pieces and that thing will look real slick!
Are you a lion?
Ryan
Thanks, I thought about that, but I'm worried about door dings. Maybe I will, not sure. I'm really happy with the truck right now. Drives perfect. Next up on the replacement list is battery and TruTrac. Hopefully both later than sooner. :lol:
Edited by kstruckcountry
Washed it haha
Helped my brother change his headlights in his 08 Malibu. I would like to have a civil conversation with the design engineer on this subject. Remove the front bumper really what the f were you thinking. The dealership wanted $200 to change the bulbs
Ryan
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
    • What are the conditions of this rich idle? Warm or cold engine? Run time? Does every idle look like this or only sometimes?
