not sure, I know that the brake job didnt go well. Leaking bad where the brake line goes into the caliper
Put new actuator in still no 4wd. Time to scrap it.
sent from my truck in a field
Scrap the whole damn thing sick of gm parts being twice the amount of everyone else but breaking the quickest
You havent bought half the parts I have. No room for you to complain lol
On another hand, I made a quick disconnect breather for my axle tube
Not actually going to use it just used it to check the threads. I use a 1/4" air hose barbed end with the 1/4-18 NPT male thread on the end. Works good so that's all that matters
Sent while drinkin' a cold one...
Ryan, guessing the spring broke or detached? Had that happen.
Broken spring
Ryan
You think GM parts are expensive..... :lol:
You haven't had a German car.
Edited by SnakeEyes
I don't care when you make nothing at your job and stupid electrical nonsense goes haywire it gets on your nerves real fast
Oil change done, new oil filter. Got 4 new shocks as well... Oh how many quarts is an 01 Z suppose to hold, its 6 isn't it?
I do 6 since it'll use it anyway :lol:
Sent from my LG-D800 using Tapatalk
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,209 Guests (See full list)
